Results 1 to 10 of 10
Thread: Holux GR-213 - Someone upload WinXP Driver?
    Variable Bitrate Phatsacks's Avatar
    May 2007
    Springfield, Va
    Got the Holux GR-213 in a package deal off mp3car's classified section, but didn't receive the driver disk, and was expecting to be able to download from holux.
    www.holux.com
    www.holux-uk.com
    and the others...aren't working
    I did try the GR-210 drivers, and they seemed to work, but it's always best to use the proper drivers for most any device.
    So if someone has them on CD, and could .zip (or any compression method), and upload them to say mediafire.com, I'd really appreciate it.
    Thanks!
    (wasn't sure if this was more appropriate under support software?)
    Sep 2007
    both my globalsat and microsoft pharos used the same driver... basically a driver that assigns the usb to a virtual com port. Scroll down here http://www.usglobalsat.com/item.asp?itemid=60
    Jae
    May 2007
    Springfield, Va
    So most likely the Holux GR-210 "driver" is the same then? I didn't bother installing it to avoid having to uninstall it. I'll check it all out now.
    Thanks ThurzNite!
    Elsewhere
    It's just a USB-to-serial driver.
    The Globalsat units (BU-353 for example) use the Prolific USB-to-serial driver.
    How about the Wiki?
    May 2007
    Springfield, Va
    Sounds good. I'll test it out tonight.
    Feb 2004
    Spartanburg SC
    i have the disc if u still need it
    just let me know and i will try and figure out how to upload lol
    Apr 2005
    I have the GM210 and GR213U both use the exact same drivers.
    From the looks of the driver disk all models use the same "USB -V2.1.0.exe" 9-3-2004 driver.
    236
    236b
    240
    210
    211
    212
    213
    213u
    230
    239
    Hope that helps.
    May 2007
    Springfield, Va
    Looks like I'm set then, I have the 210 drivers, and they seem to pull up a signal in my basement (sorta have a half window in sight).
    Very impressed with the sirfIII after seeing that.
    Thanks everyone!
    (iGuidance 3)
    Constant Bitrate faichiu's Avatar
    You should try:
    http://www.holux.com.tw
    98 Honda civic
    In-Dash LCD Monitor K-301
    cappuccino EZ3
    PIII-1.2GHZ
    256MB PC133
    40GB HD
    Holux GR 213 Sirf Star III GPS
    IguidanceV2
    CNX-P1900 power supply
    Sound Blaster Live USB
    Mar 2009
    Have to "unzip" rar. file found on Holux website
    The rar. file is like a zip file. I downloaded 7 zip @ http://files.uberdownloads.com/unrar.html which supports the rar. format and unziped the file downloaded from holux drivers page and now it works.
    It ended up being the USB -V2.1.0.exe file a few people have mentioned.
  1. Holux GR 239 anyone tried it?
    By Hindmost in forum GPS
    Last Post: 04-02-2008, 04:11 AM
  2. SD crashes on startup
    By mangus580 in forum StreetDeck
    Last Post: 10-05-2007, 12:14 PM
  3. System Choices and Questions
    By BoondockSaints in forum Car Audio
    Last Post: 08-09-2007, 11:52 AM
  4. Globalsat BU-353 vs. Holux GR 213
    By cheqmate in forum GPS
    Last Post: 02-26-2007, 09:03 AM
  5. Holux GPS 213 USB Gmouse receiver
    By virginblue in forum Classified Archive
    Last Post: 08-15-2006, 01:15 AM
