I have mine mounted with industrial velcro to the top corner of my windshield.. but I think I'm going to move it to my rear parcel shelf.
You need to have it in a window so it can see the sky. I think one of these two locations is best.
Where do you guys have your GPS receiver mounted? I thought about removing the (roof mounted) factory radio antenna and putting the GPS in its place... or does it even need to be outside the car? It's a Garmin GPS 16... your advice would be greatly appreciated!
aka Kumaneko
"Don't make me moderate your ***!"
Maxima of Doom - project thread - photo gallery
mp3car system is currently FUBAR and finances do not allow for a correction of that situation
Real computer hackers use a rotary cutting tool on their motherboard.
Speaking of putting your GPS in your back window, has anybody had problems with interference from the defrost 'wires'? I remember hearing something about them acting as an antenna and causing an echo effect.Originally posted by ShinkunoNamida
[------------------|--] 90% Completed
Not installed, yet.
Developing Completely DirectX shell.
P4 1.7GHz, 256MB RAM, 40GB-7200RPM HD
I read here a little while ago someone talking about putting it under the dash. Since its only under plastic, it didnt cause any interference.
Although i dont know if this would work, it seems like it would, and it would keep it out of sight.
Project AutoBoxen: Coming along, almost ready to hook up in the car.
Celeron 500, 192mb ram, 8gb hdd, other stuff.
'91 Mazda 626: Its free, so ill use it.
Mine's at the very front of the windshield, pretty much out of sight, easy to run the cables, and great reception.
Has anybody mounted their GPS outside the car? Is that even desirable?
I was thinking that since my Cougar has the little wire defroster lines on the hatch window, the front dash would probably be the only viable interior location, and it seems like it would have a limited "view" of the sky from there.
Any insight would be appreciated.
With many gps you can buy an external antenna. If you could find a water proof antenna you might be able to put it on the roof some how.
Other then that, i think the front dash would be the best.
Like I said, it's a Garmin GPS 16, with the antenna indivisible from the control hardware. I believe it to be weatherproof.
The 16 IS waterproof. Mount it outside your car! You'll get better reception.Originally posted by Mxyzpltk
You should probably pick up a roll of magnetic tape, and just tape it to the bottom of the GPS16 so you can remove the GPS when you feel like it. That is, if it isn't already magnetized on the bottom.
Not installed, yet.
I don't envision ever removing it... I'm planning on tightly integrating my computer with my car. I would worry about someone else detaching it and walking away with it, anyway.
Can a GPS like that "see" through fiberglass okay? What if I put it between my hatch and spoiler?
