Results 1 to 10 of 13
Thread: UK/Northern Ireland/Ireland Maps?
    Aug 2005
    Ireland
    I've read through dozens of threads about UK maps for our car pcs but I can't seem to find any information on maps for northern ireland. I've had a look at destinator 3 maps and they are absolutely useless and only have a very small handful of roads. If anyone has any uk maps I'd be greatful if they could zoom into NI and see if there's a good coverage of roads. I promise that there are really more than destinator 3 shows. The nearest road it finds to me is roughly 30 miles away. Ideally I'd like a map that I can integrate into freedrive but if there's another software that works well then I don't mind using that. Garmin maps are very good for here but i'm not sure if they can be used on a pc?
    Cheers
    Baz
    FLAC Marvin Hlavac's Avatar
    May 2005
    Garmin maps + the free Garmin nRoute software is a solution for PCs. I'm not sure how easy or difficult it would be to integrate it into a CarPC, though.
    Aug 2005
    Ireland
    It might be worth a look. Thanks for the suggestion.
    Baz
    May 2005
    If you give it a try, let the rest of us know how you like it.
    Aug 2005
    Ireland
    I just downloaded the setup file and I was wondering if I need map files or anything else?
    The huge lists of maps and map types on the web site is very confusing.
    I might get some time later and get it installed. I can't wait to test it out because the maps are 10 times better than destinator.
    Any help is much appreciated.
    Cheers
    Baz
    Aug 2005
    Ireland
    OK so now I've got mapsource and nRoute installed. My next step is to get the software to see the gps reciever. It's on a usb connection and with my other testing software I can see that it's on COM port 4 but when I go to the nroute software and check for usb devices it says that there is no device there at all.
    Is there some sort of configuration I have to go through or some sort of patch needed to pick up all the different types of recievers.
    Cheers
    Baz
    P.S. the fact that it installed has impressed me more than some of the other software I've tried.
    May 2005
    It must be just a matter of configurating GPS Gate properly. I don't sit in front of a PC with GPS Gate on it, but likely you need to specify that the input device is a Garmin-type receiver.
    It shouldn't matter that you are using an unregistered trial version of GPS Gate.
    Maximum Bitrate Valheru's Avatar
    Jul 2007
    Ireland
    Can either of you explain how I get the nRoute software to install. I downloaded the software from the garmin website but upon installatoin it seems to be looking for a pre installed Garmin software package - which I do not have.
    Is the nRoute software free ??
    Mar 2007
    NMEA
    Sorry, no NMEA connections with work with nRoute, it uses the Garmin format only, but again most newer era Garmin units will work with either serial or USB connections.
    http://www.gpsinformation.org/penrod/nroute/nroute.html
    Aug 2005
    Ireland
    Quote Originally Posted by warren222 View Post
    NMEA
    Can you explain this please and also explain GPS gate as you seem to know about these things?
    I might just try gpsgate later and see how it goes as I saw on another thread that the globalsat BU353 usb reciever works.
    Baz
