Results 1 to 6 of 6
Thread: Pc rebooting while soft is connecting GPS :(
    Variable Bitrate felix99's Avatar
    Apr 2002
    Europe
    Angry Pc rebooting while soft is connecting GPS :(
    Hi,
    i'm triing till 3 h to get this damn gps i bought to work. Everytime when i start navigation my computer reboots
    Have GPS USB receiver winxp and travelbook .
    Anyone having had same problem ?
    Felix
    =>> Carpc Version2 -- Epia M 10K based<<=
    ::Epia M10k,7"VGA/40GB2.5",GPS,Opus90W ::
    ::trying to build second low cost carpc::
    ::Automp3.de :: CAR= Renault Clio2 - 2 seats 1.9D
    Apr 2002
    Europe
    tried to log with hyperterminal: my record 6min before rebooting- after disabling the auto reboot option of winxp i got a blue screen saying BAD_POOL_CALLER
    google says => mosty grafic card problems - but what the H*** has my gps to do with my grafic card ?
    Any solution - working on it since approx 9 h - no success -
    Fx
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    WinXP uses ports differently than win98. I would look up your software and make sure it is WinXP compatible...also there maybe a hardware driver patch for the GPS.
    Apr 2002
    Europe
    Hi, Thanks for your answer.
    what i recently did to check out:
    - made new install on other hdd => same error
    - installed it on my homepc(also XP) -=> works fine
    i have a special xp driver - ( its called host bridge - just to give a virtual com port to usb gps )
    Now my last chance is a USB PCI card - it it won't work i have 2 possibilitys - change the mainboard and buy a new one [too expensive]
    or try to change the gps in a normal com-port one. [depends if the seller wan't to]
    Regards felix
    Apr 2002
    Europe
    Finally got it working! but tested only on my new test install HDD . will port the config tomorrow.
    so the why and who of the story :
    who ? the damn onboard usb was the bad guy in this story - know i have a pci USB card and it works ( when i disable internal onboard usb )
    why - don't know because my DAP jukebox worked fine on the onboard usb - probably because i only connected the datapins because jukebox connected to my front panel doesn't need any current.
    so i hope it will work on the other install tomorrow
    I posted this reply to help people with same prob's in future .
    felix
    Apr 2002
    Europe
    Finally got serial Receiver and all is working now
    Think I'll never know why I had the probelem with this damn USB GPS receiver
    Felix
    If you ahve the same problem - try to get a serial gps !
