Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Using a microprocessor to display GPS data on an LCD
  1. #11
    Aug 1999
    Washington D.C.
    Enough on the lat and long display. It’s not for everyone but, I’m a geek.
  2. #12
    Oct 2002
    The basic stamp II and basic X are similar, X is faster more I/O, ram, etc. You might also look at the parallax javalin. This is a java based stamp. Lots of I/O, memory and fast.
    Also if you didnt know, Yahoo groups has a basic stamp support fourm.
  3. #13
    Aug 1999
    Washington D.C.
    I decided to that I would return my Basic Stamp II and instead buy the BasicX. It should be here next week. With a student discount I'm gonna get a much more powerful processor for about $30 cheaper.
  4. #14
    Jul 2002
    Downey, California
    Zip-Lock - You could have just added some external RAM. I know it sounds like a pain in the butt, but I do it all the time. And while you were at it you could have added some EEPROM for data logging. So when one of your buddies/kids/wife/g-f/etc. borrow the car, you can see where they took it. It's also good for making your own maps, and whatnot.
    [------------------|--] 90% Completed
    Not installed, yet.
    Developing Completely DirectX shell.
    P4 1.7GHz, 256MB RAM, 40GB-7200RPM HD
  5. #15
    Oct 2002
    If its variables he ran out of then ram doesnt help that. It might be the way the variables are being used. He might be saving Bitwize variables as bytes. Adding memory is pretty easy but its serial memory and you have to write code to save to memory.
  6. #16
    Jul 2002
    Downey, California
    You just load and unload the variables needed at any given time. The Basic Stamp IIsx has 8 pages of program memory which allows you to block your variable groups much more easily. I've successfully used up to 64 double word variables at one time. You just have to get creative and use your imagination.
    When you change a page have it load all the variables from your serial (there are other types you CAN use) RAM to your chips registers, and when you leave that page have it load all the variables back to the serial RAM. As a bonus, this makes it all easily accessable from the other pages without having to tie up your 'scratchpad memory'.
    The reason you use external RAM instead of internal EEROM memory space for variable use is that you can only write so many times to any address. If you exceed this limit, you'll end up with a dead byte (which sucks). RAM on the other hand allows practically limitless writes. But you knew that already!
    Not installed, yet.
