Is it a PCMCIA GPS card? I had an etak GPS with sony Software back in 2003. On the GPS unit there is a small switch that enable you to select rockwell binary or NMEA output.
If not, then its not worth messing with it. You can get a hardware based that translate the rockwell to NMEA, they cost more than a decent SIRF3 unit though. If you are lucky you might find a software version of this translator.
To tell you the truth that GPS is crap, I mean real crap. The fix time is like 30 minsI got lost a few times cause of its crap sensitivity and crap fix time. Bin it and save yourself the hassle.
LinkBack URL
About LinkBacks
. I was hoping for some sort of program that still used it. What about older versions of S&T from like 2003 or SA2003. will those work with this? I just want somthing other then Skymap Travler. So any other suggestions???
