Results 1 to 5 of 5
Thread: auto start xport to be preconfigured
    Oct 2007
    little rock
    I can't seem to get any hits when I search for this problem.
    I am using the free Xport (please donate if you can) it works great.
    I am basically using it to save a continous GPS data log.
    It is just an exe file that I run, but how can I make it autorun with my current settings? Are there some commandline switches for xport
    Or does anyone know a better way to be able to create a continous log of gps data without messign with Iguidance 3 functionality.
    Thanks in advance
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    ?? Xport autoruns once you have ticked 'Enable Ports' and closed it.
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Ah, without using the splitter it won't autostart. Yeah, just select a virtual port and enable and it will autostart.
    Thanks much for the donation too!
    Oct 2007
    little rock
    Awesome, Thanks dudes,
    It was so easy It threw me for a loop.
    Your welcome on the donation. Well worth $5.00.
    I did as you said and it all works perfectly.
    What is your favorite gps log reader?
    Mar 2004
    Florence Yall, BFKY
    I just use my compass app to read it on the home PC. The speed isn't accurate, but I don't need that. Compass knows when XPort is available. Just set up XPort with a virtual port enabled and compass with play back to iGuidance or anything else. You just have to use regedit to set the log folder for compass to find it. I should probably do something about that but I don't know if anyone really uses it for that.
    On the other hand, just load iGuidance and hit "Play Track" under File. There's no speed control though.
  1. MS Streets & Trips auto start GPS
    By davem in forum GPS
    Last Post: 10-29-2006, 12:11 PM
  2. Auto start Mappoint when RR starts?
    By Zogg in forum Road Runner
    Last Post: 10-28-2006, 06:23 PM
  3. Problem with alarm - remote start (fuel pump off?)
    By urosbe in forum General Hardware Discussion
    Last Post: 10-19-2006, 09:47 AM
  4. Carnetix Pulse Start to Alarm.
    By bluehcc in forum Power Supplies
    Last Post: 05-18-2005, 02:59 PM
  5. Winamp auto start of visual plugins!
    By Norman in forum Software & Software Development
    Last Post: 03-10-2000, 04:05 PM
