Results 1 to 9 of 9
Thread: bu-353 satellite fix problem, no fix anywhere !
    Jul 2007
    hey everyone, apart from having the most updated drivers for the bu-353, when i load GPS information the software provided,
    and centrafuse, my bu-353 seems to not get a fix anywhere outside and even at different locations no matter how long it scans,
    anyone have any ideas or have I bought a faulty bu-353 ?
    the thing i I did have a dodgy ebay gps receiver, at that manages to establish a signal when in gps mode for centrafuse ...
    have I dont something wrong ?
    settings are correct with baud of 4800, 8 bits stop bit 1, and parity none,
    com port correctly detected aswell GPS information seems to not get any fix at all
    Elsewhere
    Can you open up a terminal (like HyperTermnal built into XP) ont hat COM port? If you do you should see the raw data stream from the GPS, even if it's not getting a lock.
    If you're getting gibberish or nothing at all, your BU353 may be defective.
    How about the Wiki?
    Jul 2007
    i am getting a stream of data from GPS information, most times in the other window i get satellite numbers with green and red circles but no lock http://img72.imageshack.us/img72/5850/gpsmd3.jpg
    heres a sample of the raw dump i get from GPS information
    $GPGSA,A,1,,,,,,,,,,,,,,,*1E
    $GPGSV,3,1,12,24,83,340,28,09,83,161,29,21,38,323, ,29,30,224,*71
    $GPGSV,3,2,12,26,30,005,,06,29,225,,15,24,325,,10, 23,075,*75
    $GPGSV,3,3,12,02,22,145,,05,21,181,,30,12,196,,18, 08,319,*72
    $GPRMC,115421.949,V,,,,,,,190108,,*28
    $GPGGA,11542
    heres a sample of what i get from the hyperterminal
    †`````````xffx``````x`ff`ffff```````f````
    ``````f``````f````````````````````f``
    Elsewhere
    Well, that's not NMEA data. That's Sirf data, I believe.
    You need a tool to switch from SIRF mode to NMEA mode so your GPS application can read the NMEA data.
    SIRFDemo can do this, I'm pretty certain.
    How about the Wiki?
    Feb 2010
    Any updates? I'm not getting a fix anywhere either...
    Jan 2008
    Dartmouth, MA
    Quote Originally Posted by UnkellSam View Post
    I'm sure DarquePervert will give you hell for digging up an old thread, but, I've also gone through this problem so I'll answer. That way next time someone searches, we know they'll find it.
    Anyway, GPS pucks can get a lot of interference and a lot of obstruction. Mine would get a fix one day, then not work for two weeks, then get a fix for a little while, so on and so forth.
    What ended up fixing it was putting the puck outside of the car. Away from all interference. Even though the prior location had been on the rear deck.
    Try moving the puck outside and then give the thing up to 2 minutes to get a fix. Make sure you're not in a garage at the time. That will let you know what's really up.
    Also, you don't give very much information, so you could have the wrong com port set. I don't know what your knowledge level is or how far you've chased this problem yourself.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
    Feb 2010
    Well, I don't know too much about GPS. My car is a convertible, and with the top down I still don't get a fix. I'll try placing it on the outside of the car to see if it helps, but its definitely not how I would like to have my permanent setup... If my cell phone gets GPS signal, then I would expect a dedicated GPS receiver to be able to as well. Especially considering people are reportedly getting signal with this receiver inside buildings. I'm in urban Los Angeles, not an obscure mountainous region or anything.
    My OS is Windows 7 32 bit - With the GPSInfo software I only have red circles and "No Fix". There's is an ongoing string of text displayed in the GPSInfo software when I activate the com port.
    In GPSInfo I am set to com port 6 - that is where the receiver is set to - I did a scan in GPSInfo and it locates the receiver on com 6 with no problem...
    I'll try reinstalling the drivers, maybe thats where the problem is...
    Jan 2008
    Dartmouth, MA
    What is the baud rate set at? It should be 4800. Sometimes the buggers set themselves to 9600.
    Feb 2010
    Quote Originally Posted by PaulF View Post
    It is set to the default 4800.
  1. Problem I was able to fix
    By Rundell in forum PhoneControl
    Last Post: 01-19-2005, 03:01 AM
  2. Lilliput connector problem? is there a fix?
    By tmar89 in forum LCD/Display
    Last Post: 09-19-2004, 05:02 AM
  3. My fix for the VW VR6 shifter problem.......
    By VWTronics in forum Off Topic
    Last Post: 08-20-2004, 08:15 PM
  4. Can't fix my powering problem
    By Vicked in forum Power Supplies
    Last Post: 11-20-2003, 05:37 PM
  5. I know the problem but dnt know how to fix it?
    By corsamel in forum General Hardware Discussion
    Last Post: 08-18-2003, 12:11 PM
