Results 1 to 4 of 4
Thread: GPS Antenna Mounting in a Jeep
    Jan 2008
    Los Angeles, CA
    Greetings, all. I'm new to all of this and am about to embark on my jeeputer project. I've noticed a few TJ owners posting in this forum and have a question for you...
    What GPS antenna did you use, and where did you mount it? It appears as if the USGlobalSat BU-353 is fairly popular but my initial impression is that it is too wide to fit in the roll bar padding.... because IMHO putting a GPS antenna inside the padding of the roll bar is by far the best location as it would be on the top of the vehicle and I can neatly run the wires out of sight back to the 'puter.
    Thoughts?
    Anyone know of a slimer GPS antenna on the market? (doesn't have to be waterproof as it will remain inside the vehicle)
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    I used to own a TJ and I had my XM sat radio antenna on the roll bar, under the padding. it fit in there fine and it worked great.
    I don't have my jeep anymore, but I DO use a Globalsat BU-353 antenna and I can tell you it's almost the exact same size as my XM antenna. I can't imagine any problem at all fitting it under the padding. if it really was a tight fit then you could always cut out some padding (you won't see it because it will still have the nylon cover over it)
    I know first hand that the BU-353 works great so I can highly recommend it
    good luck with your carPC
    Jan 2008
    Los Angeles, CA
    Thanks for the quick reply -- I think I'll give it a shot and let everyone know if it fits. It'll be perfect if it does...
    Newbie FTWRUBI's Avatar
    Nov 2007
    Ft Worth, Texas
    You can notch the foam around the roll bar and it will fit great. I installed a tuffy overhead console and that is where all of my puter stuff is going except the screen. I will post some pix when I get done.
  1. Replies: 11
    Last Post: 09-13-2011, 12:14 AM
  2. Replies: 65
    Last Post: 10-13-2009, 07:51 PM
  3. Replies: 26
    Last Post: 08-14-2008, 08:49 PM
  4. Replies: 11
    Last Post: 12-06-2004, 04:48 PM
  5. Gps Module + External Antenna + Waas + Usb
    By e_z_street in forum GPS
    Last Post: 10-06-2004, 04:57 PM
