Results 1 to 10 of 15
Thread: Iguidance 4 install location
    May 2003
    It seems that iguidance is hardcoded to look for maps/any other stuff from c:\program files/....., is there any way to tell iguidance to look for program files from a different location? Like d:\iguidance, or something? This is pretty poor programming on iguidance's part if they hardcode such a thing....i may have to look for an alternative solution if i cant change the location.
    Oct 2006
    i'm not sure if this is wat you want, but installed iguidance then place a copy of the image file on another drive, and mount that drive with a virtual iso program, and that worked perfectly. Hope that helps you out. If you want a free program its called magicdisk or magicdisc.
    Aug 2007
    copy the installation files to the root of any local hard drive (C: for example), run setup.exe from the hardisk instead of the CD.
    IGuidance will then load the maps from the hard drive it was installed from.
    Stav
    May 2007
    Bothell, WA
    so since i have mine installed, i have to uninstall it and reinstall it again but without the cd? what about the license key? that will be reusable?
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    i have my maps on d:\inav\iguidance and my install in C:\program files\inav\iguidance. It pick up my maps without me even routing it. This is how i have been installing my iguidance 4
    Jun 2006
    Houston, TX
    you can just move the map files to d:\ or any other location
    May 2003
    Moving it doesnt work. I've even tried with copying the install CD to the location where i want to install, then reinstalled. When i load up, it says Cannot find map data files.
    I moved the install files to d:\apps\iNav Guidance\Setup
    The maps are in d:\apps\iNav Guidance\Setup\Maps\
    I installed to d:\apps\iNav Guidance
    Aug 2007
    Important part.. The root directory.
    Copy the setup files to D:\
    So you have;
    D:\setup
    D:\iNav iGuidance
    D:\setup.exe
    etc..
    Then re-install
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    the manual only gives instructions for the C: drive, but I think it will work on other drives as well but it has to be in the drive root. in other words you cannot have it in your "apps" folder, it would need to be in D:\iNav iGuidance\
    just move it into the root and it should work fine
    May 2003
    Thanks guys, root folder works!
  1. Replies: 2
    Last Post: 10-10-2007, 09:24 AM
  2. Replies: 1
    Last Post: 09-21-2007, 09:24 PM
  3. any way to install Iguidance without dvd drive?
    By Snortonnorton in forum GPS
    Last Post: 07-16-2007, 01:12 PM
  4. Can't get Flash Player to install
    By boat in forum Newbie
    Last Post: 12-10-2006, 02:49 PM
  5. Iguidance Install Problem
    By tbird2340 in forum GPS
    Last Post: 01-08-2005, 10:44 PM
