Results 1 to 7 of 7
Thread: IG4 map and position accuracy
    Jul 2006
    anyone notice in IG4 that your position on the map is not as accurate as it was in IG3? maybe they changed their algorithm, but i have noticed a few times when it temporarily puts me on the wrong road or puts me past an intersection while i am waiting to turn at it (as if i went straight through it), causing an entire reroute. this never happened in IG3, i wonder....
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    I run iGuidance 4 and I've never had that problem. it may be a problem with your receiver, not the software?
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    i've noticed it in areas were a merge lane or a turn-off lane is right next to where i am.. its never been a problem tho because i just continue on the road instructed and it fixes itself.
    Live mp3Car Facebook Chat
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    I've noticed how in 3D mode it looks like you're past an intersection but if you switch to 2D mode you're not.
    Jul 2006
    hmm. im usin the same receiver, but i never noticed these things in ig3. i guess its just in my head then
    May 2007
    Boston
    I use a GlobalSAT BU-353 USB receiver... what are you using?
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    The other day I was sitting at a stop sign and it said to turn in 50ft then after I turn it figured out I was on the road to turn on, and other times it tells me to turn a couple cars before I get there. Doing 70-80 it may say turn in 500ft when I hit the offramp. Is it lag or is it accuracy? Or both?
  1. RELEASE: Map Monkey v1.1.3
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-12-2009, 11:27 AM
  2. Loss of Map projection, white background only - 1.0.8.1 - 1.1.1.0
    By geeky_hawkes in forum StreetDeck Bug Reports
    Last Post: 02-18-2008, 08:13 PM
  3. GPS / Map Point current position
    By skippy76 in forum RR Bug Tracker
    Last Post: 10-10-2005, 12:42 AM
  4. Map Monkey sdk center map command....
    By feelgood in forum Map Monkey
    Last Post: 05-28-2005, 07:31 AM
  5. Replies: 0
    Last Post: 04-02-2005, 10:44 AM
