Results 1 to 7 of 7
Thread: MS Street & Trips 2008
    Maximum Bitrate nasa's Avatar
    Aug 2006
    PA
    Hi,
    Has anyone tried this version out? Info is here:
    http://www.microsoft.com/streets/Pro...e_tab=Features
    Note it includes MSN Direct.....
    http://www.msndirect.com/NavigationD...x?tab=Overview
    That leaves me with some questions:
    1. does the antenna work with xport?
    2. does it work with any frontends?
    3. How good is it in general?
    Thanks for the input....
    Nasa
    Constant Bitrate coffeejolts's Avatar
    Jan 2006
    Duluth, GA
    I haven't used the 2008 version. I have 2006, and I am pretty disappointed in it for car pc use because of the interface. I'd be interested to know if it has an activeX control version available.
    Dec 2006
    There's a RR skin add-on for Streets and Trips. I've been using it since Trips 2006. It should work for 2008 unless they changed the interface.
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    I use Iguidance 4 in the car, but I prefer S&t for route planning.
    I've used 2008, seems fine, pretty much like the previous versions with a few new features and updated maps.
    The GPS puck should work fine with export as all xport does is split the port into a couple virtual ports. Remember, I said should............
    I don't think any of the current skins or FE support S&T by default due to the interface issues mentioned above. You can embed it and it will work fine, I have before but switched to IG 4 for the 3d view.
    Leonardo Da Vinci
    FLAC Marvin Hlavac's Avatar
    May 2005
    If interested, there is a mini-contest going on right now at - you may win one of two MS Streets & Trips 2008 with Connected Services (the version which includes the program, the GPS receiver, and the MSN Direct traffic receiver). Here's the link.
    Aug 2006
    PA
    Thanks for the replies,
    What I really was wondering is if MSN Direct works well with any of the frontends? Since S&T 2008 includes that for a year, it looks rather attractive....
    Nasa
    Jan 2006
    Duluth, GA
    To my knowledge, none of the front-ends can make use of MSN Direct right now. Is there a sdk available? If so, I'm sure a plug-in could be written.
  1. Replies: 6
    Last Post: 11-02-2006, 10:13 PM
  2. Site always down
    By mg52 in forum Mp3car Forum Suggestions/Comments
    Last Post: 03-15-2006, 10:49 AM
  3. MS Street and Trips 2005..questions
    By gambit32 in forum GPS
    Last Post: 10-13-2004, 09:46 AM
  4. Replies: 4
    Last Post: 05-07-2003, 11:15 AM
