I run this setup in my truck with no issues. I can send you the files. Where would you like them sent.
I just installed my old AyAy Sir gps into my new setup. At first i keep getting BSOD, then installed the latest xport and now xport keep crashing on its own. I know this setup works fine with older version of xport.
Anyone know how to fix this? or have a copy of old version of xport? something like 1.13 would probably do.
Thanks.
I'm getting the same error with xport3. It brings up the microsoft error, send or don't send and I click don't send then the program ends.
Oh my bad. I recently rewrote a lot of code and guess I didn't test it too well. It was crashing if you have the log turned off. I just updated it on my site. Sorry about that.
ohhh! sweet, thanks for the quick update.
quick question for you curiosity. whats the difference between sync/async for xport?
thanks fixer, i'll try the newer version first, and i'll get back to you if it doesnt go too well.
Those are just two different methods of reading from the COM port. Async is the old way, which is faster but could be the reason it has trouble with some GPS drivers. It's more difficult to implement. Sync just polls for bytes and reads them on a 100ms interval. I'm hoping that I get some feedback someday if one doesn't work with some odd GPS out there, but really they should both work.
Okay so I redownloaded xport, then I opened it up and noticed that the three virtual ports I enabled previously are not listed. So I choose three other ports, 2,3, and 10 and click enable. When I go into road runner and click gps, it says waiting for signal and never connects. But when I go back into xport and unclick the enable ports, gps works fine in rr. What gives?
Ooh that's bad. The ports that aren't listed weren't put back in the free list. Hit Scan. I don't know about RR working when you unclick enable ports. Maybe it got inverted somehow, but I haven't seen that happen.
version 1.20 worked flawlessly, but i noticed it took a lot longer to lock-on to sattelite.
Anyone else experiencing the same problem?
My Ayay Sir gps and x port takes longer to lock than on my laptop, but its not out of hand. maybe 1-2 minutes. Im not sure whether im using xport 1.2, or older. Its the one that came with DFX skin. I think its 1.16 ?
Car Pc progress meter:
[-----------------85%---] Looking good! Total spent : $740, Thats including two touch screens!!!
"The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
My worklog
