Am I reading this right, you are trying to use your GPS with two applications on the same port? If that's the case you cant do that you need to split the ports with a port splitter like xport or similar. A GPS port can only be used by one application at a time. If you don't want to use a port splitter the take a look at freedrive instead as RR will talk directly with that and get all the GPS info it needs.
LinkBack URL
About LinkBacks
