Page 14 of 20 FirstFirst ... 4567891011121314151617181920 LastLast
Results 131 to 140 of 196
Thread: Igo 2008
  1. #131
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by BlackStealth View Post
    Tried out IGO8 for the first time and noticed it sometimes lags badly. For example, I came off the highway and made a right hand turn. IGO8 makes an announcement to make a right hand turn soon -- puzzled I glanced down and noticed it was lagging about 5 seconds where I was. I'm guessing my dual core Atom 330 doesn't have CPU muscle to handle this app properly???
    I get a mixed feeling with IGO8 when comparing it to iGuidance 2009. IGO8 is prettier and has some cool new features but the map data is very old for Canada. Street addresses can be off quite a bit (approx 20 houses), one highway I drive has existed over 5 years but doesn't exist on the map.
    To support this software company somehow, I ordered a GPS device equipped with IGO8 from ebay.
    are you using it with xport or straight to the gps port?
    Live mp3Car Facebook Chat
  2. #132
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Wow, is it for sale already? I'm using the demo and starting to like it. It does use a lot of CPU though. Well, for me it's the Intel graphics that kills it and this is a 2.4GHz P4. So bring up task manager and check the performance. They have some kind of prediction between position updates so it's constantly drawing to make it look smooth.
  3. #133
    Mar 2006
    Blog Entries
    1
    Quote Originally Posted by Sonicxtacy02 View Post
    Yes I'm using xport. Going direct makes it work better?
    Curiosity: I purchased the GPS PDA version (not the PC version) of IGO8. The PC IGO8 version is not available for purchase.
  4. #134
    Woodbridge, VA
    Blog Entries
    55
    it can. i'm experiencing that problem. Going direct makes it work just fine. Funny thing is my last mobo .. ALSO intel.. had no such issue. Sure do wish i knew a fix for it.
  5. #135
    Jul 2006
    Belgium
    I'm running iGO on a netbook equipped with an Atom 270 with 1Gb of ram and that combination handles CF, playing mp3's and iGO very well !
  6. #136
    Mar 2006
    Blog Entries
    1
    Thanks for the feedback. I'll experiment with a newer version of Xport, or remove xport completely, or turn off "hyperthreading" and see what effects there are.
  7. #137
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    are the maps for a pda the same as the ones used in the pc version?
  8. #138
    Woodbridge, VA
    Blog Entries
    55
    make sure to post results. Maybe we can solve the issue.
  9. #139
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    The PDA maps work, although some of the newer map versions need to be patched.
    I am running iGO on a intel Atom with 1gb RAM and it works really smooth.
    For what it's worth GPS is not 100% accurate all the time, if you don't have a good gps fix the movement is not going to be accurate. Many things can effect this, such as weather, receiver position, where the satellites are in the horizon, building, ect. It's just the nature of the beast. I don't see anything wrong with iGO and it's GPS positioning, it's all in the GPS data you are feeding it.
  10. #140
    Jul 2005
    Motorcity
    Blog Entries
    1
    Just a FYI, iGO runs remarkably well under wine on my FreeBSD server. It actually launches faster than it does on windows! gpsd works good to so this looks like a good solution for running GPS on the 'nix platform.
  1. Replies: 11
    Last Post: 02-10-2008, 12:10 AM
  2. which 7" is better? 2008 Lilliput or 2008 Xenarc
    By poisonspider in forum LCD/Display
    Last Post: 01-02-2008, 12:24 AM
  3. Replies: 1
    Last Post: 09-08-2007, 03:17 PM
  4. Microsoft Streets & Trips 2008, AutoRoute 2008
    By Marvin Hlavac in forum GPS
    Last Post: 08-22-2007, 12:02 PM
  5. How igo on ipaq 3955
    By rony1981 in forum GPS
    Last Post: 09-01-2006, 10:35 AM
