Page 20 of 20 FirstFirst ... 1011121314151617181920
Results 191 to 196 of 196
Thread: Igo 2008
  1. #191
    Mar 2010
    Talking
    All good. Check the attachments I've actually figured out how to fix it. Very simple indeed. Just replace the voices with mine.
    Have a look here:
    http://www.digital-car.co.uk/forum/s...postcount=2988
    http://www.digital-car.co.uk/forum/s...=8795&page=200
    Also, I've also found why for some people TTS works and then on next load it does not. You have to delete your route before exiting iGO, or delete it and reset it when you load iGO. Is there a sys file command that can automatically delete a route when you exit iGO? Because you can simply use the history function to set your destination again...
  2. #192
    Jun 2010
    Romania
    is there any chance that you can reupload your skin somewhere? The links are no longer valid
  3. #193
    Jan 2006
    Dublin, Ireland
    I have a problem with the GPS which is doing my head in. I am running iGo 8.3.1 with an external BT GPS. If I run it outside of RideRunner, Bluesoleil connects straight away (on Com Port 5) and I get the Blue arrow indicator on the map indicating my position.
    However, when I run it via Riderunner using this skin, the iGo loads up OK, the BT icon turns green and indicates that BT is joined to my GPS device, but it just will not show the location and within iGo, it indicates that it cannot find the GPS. In Bluesoleil, it shows that it's connected to my GPS. It nearly seems like something within Riderunner is also trying to use Com Port 5. The only other thing using BT would be the Headset Voice Gateway on BlueSoleil (ver 10.0.417.0)
  4. #194
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by championc View Post
    Do you have RR configured to use the GPS? Check rrconfig
    Sent from my SCH-I535 using Tapatalk 4
    Live mp3Car Facebook Chat
  5. #195
    Jan 2006
    Dublin, Ireland
    Quote Originally Posted by Sonicxtacy02 View Post
    It is all configured perfectly. I runs fine but just never showed the current position - but everything else was perfect. On the RR Reborn Skin thread, another user suggested I install Xport and this has worked perfectly.
    I still have one final issue to resolve. iGO runs inside the Reborn Skin but the buttons along the bottom of the skin hide over the "Cockpit", "Map" and "Exit" buttons i.e. the bottom functions bar. Can I somehow re-size the iGO to run inside this Reborn window ?
    I found iGo-MySize but it doesn't seem to want to work ?
    I tried using iGOZoomer but this gives an error saying that the maps are out of date which they definitely are not.
  6. #196
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    RISE FROM YOUR GRAVE!!! Actually I'm glad this thread did. ::fires up iG08::
  1. Replies: 11
    Last Post: 02-10-2008, 12:10 AM
  2. which 7" is better? 2008 Lilliput or 2008 Xenarc
    By poisonspider in forum LCD/Display
    Last Post: 01-02-2008, 12:24 AM
  3. Replies: 1
    Last Post: 09-08-2007, 03:17 PM
  4. Microsoft Streets & Trips 2008, AutoRoute 2008
    By Marvin Hlavac in forum GPS
    Last Post: 08-22-2007, 12:02 PM
  5. How igo on ipaq 3955
    By rony1981 in forum GPS
    Last Post: 09-01-2006, 10:35 AM
