Page 4 of 20 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 192
Thread: Igo 2008
  1. #31
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    yes
    Live mp3Car Facebook Chat
  2. #32
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    I've got all the buildings, not sure how new my data is though, the POI's treetop sent me are much newer.
  3. #33
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Most likely "3dl" yea the buildings.
    What state?
    EDIT: OOps, didn't see all these responses.
  4. #34
    Jul 2005
    Motorcity
    Blog Entries
    1
    Have iGO embedded nicely into RR, it does have some focus issues I am trying to work out. Still cannot figure out the "start" position either.
    I have all the buildings, I got them from a PDA source
  5. #35
    Sep 2003
    Souf Cakalack
    ^the program is looking for a GPS position. Try using this, http://franson.com/gpsgate/, its a gps simulator. Find your lat, long position via google search and enter it into the program. Set it to output on COM2 and open up Igo and search for GPS signal. This is what I used to test Igo.
  6. #36
    Variable Bitrate Spawn12336's Avatar
    Nov 2005
    Toronto, ON
    The start position is defined on the first run using 2 variables in the sys_pc.txt in the [gps] section. mine is downtown Toronto.
    default_latitude=43.643978
    default_longitude=-79.388663
    Just change them to whatever you want them to be. If you have already run the app, go into the save folder and delete the 2 settings files. it will run through the first time setup when you run it again.
    After that, as soon as it gets a valid signal, it will keep that everytime it runs.
    "the universe has a way of balancing itself"
    http://i15.photobucket.com/albums/a3.../Webbanner.jpg
  7. #37
    Jan 2009
    subscribed
  8. #38
    Jul 2005
    Motorcity
    Blog Entries
    1
    Quote Originally Posted by Spawn12336 View Post
    This worked perfect, thx.
  9. #39
    Jul 2005
    Motorcity
    Blog Entries
    1
    For Embedding Reference:
    Add
    Code:
    render_without_focus=1
    to iGO8 sys_pc file [debug] section.
    This will allow iGO to continue rendering while embedded in RR and the focus is on RR.
  10. #40
    Variable Bitrate Ramanator's Avatar
    Feb 2007
    Motor City
    blko2si,
    Do you have the maps for MI?
    If you cant DODGE em, RAM em.
  1. Replies: 11
    Last Post: 02-10-2008, 12:10 AM
  2. which 7" is better? 2008 Lilliput or 2008 Xenarc
    By poisonspider in forum LCD/Display
    Last Post: 01-02-2008, 12:24 AM
  3. Replies: 1
    Last Post: 09-08-2007, 03:17 PM
  4. Microsoft Streets & Trips 2008, AutoRoute 2008
    By Marvin Hlavac in forum GPS
    Last Post: 08-22-2007, 12:02 PM
  5. How igo on ipaq 3955
    By rony1981 in forum GPS
    Last Post: 09-01-2006, 10:35 AM
