Page 8 of 20 FirstFirst 123456789101112131415161718 ... LastLast
Results 71 to 80 of 192
Thread: Igo 2008
  1. #71
    Constant Bitrate lacning74's Avatar
    Apr 2008
    fyi, here's a screenshot of my Centrafuse/Igo8 set-up. this evolving "demo" has become my primary gps over Garmin Mobile PC. i'm dreaming that igo8 will officially integrate this in Centrafuse 3.0.
  2. #72
    Low Bitrate mcfly's Avatar
    Dec 2007
    Romania
    Is there anyone successfully using iGO8 PC and Nokia LD-3W?
    My receiver works with every other software, but iGO8 kills the serial port service, after the first connection. Then the receiver must be restarted, and sometimes the stack must be reinstalled. It's the same with iGO 2006 PC.
  3. #73
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    what skin is that lancing?
    Is it easy to install different skins for iGO? I've been using twingos, it came preinstalled in the iGO package I found on the interwebs
  4. #74
    Apr 2008
    Quote Originally Posted by blk02si View Post
    Spawn's skin. Check out the digital-car.co.uk forums. LeZandre started a thread there posting all the different skins, maps, and files. Not hard at all once you do it a few times.
  5. #75
    Jul 2005
    Motorcity
    Blog Entries
    1
    Thx lacning, I just downloaded about 3 Gb's of data to play with
  6. #76
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    my jumping list problem was solved in doing the new pc install. i guess igo8 doesnt like little 1.33ghz pcs .
    Live mp3Car Facebook Chat
  7. #77
    Jul 2005
    Motorcity
    Blog Entries
    1
    iGO was designed for small CPU's but i think the emulation layer causes it to take more resources.
    Lancing, 1 more q for ya, I'm messing around with spawns skin, which is stellar, the only thing I cannot figure out is how you get the left bar transparent like you have? I'm inclined to believe it's a different version of the skin since I cannot find an option for it anywhere.
  8. #78
    Jul 2006
    Belgium
    Easy answer: Like lacning74 already wrote: " That's a Spawn skin". (It's perhaps just one of his more recent ones than you're using.)
    Nothing to configure, start it up and it should be transparent.
  9. #79
    Jul 2005
    Motorcity
    Blog Entries
    1
    I'll see if I can find some different versions, since I like the transparency better. Most likely it's just a slightly different data.zip file. Also loving the animated menu option, so cool!
  10. #80
    Jul 2006
    Belgium
    Spawn doesn't recompress the data.zip anymore, works just as fine.
    You can find all the links to files here.
  1. Replies: 11
    Last Post: 02-10-2008, 12:10 AM
  2. which 7" is better? 2008 Lilliput or 2008 Xenarc
    By poisonspider in forum LCD/Display
    Last Post: 01-02-2008, 12:24 AM
  3. Replies: 1
    Last Post: 09-08-2007, 03:17 PM
  4. Microsoft Streets & Trips 2008, AutoRoute 2008
    By Marvin Hlavac in forum GPS
    Last Post: 08-22-2007, 12:02 PM
  5. How igo on ipaq 3955
    By rony1981 in forum GPS
    Last Post: 09-01-2006, 10:35 AM
