Here is what I got cooking
Code:
[3d_config]
disable_3d_labels=0
disable_roadsign_navigation_mode=1
;0= Streetname inside textballoon
;1= Streetname embedded on the streets
[3d_config]
roadsign_lines_per_screen=20
rotated_roadsigns=1
[debug]
show_lane_info=1
skip_eula=1
enable_roadshadow=1
show_lights=1
show_oneway=1
log_tmc=0
show_tmc=0
enable_speedcam_functions=1
poi_labels=1
speedcam_enabled=1
[gps]
port="9"
baud="4800"
set_messages="0"
[interface]
skin="ui_igo8"
resolution_dir="400_240"
vga=1
mapfontscale=110
laneinfo_signpost_enabled=1
[loading]
show_statustext=1
show_progressbar=1
progressbar_x=18
progressbar_y=220
progressbar_bmp="loading_progressbar.bmp"
[rawdisplay]
highres="1"
screen_x=800
screen_y=480
[poi]
enable_pois_before_080217=1
multipoi=1
[warning]
speedwarn_alt_builtup_based=1
pedestrian_warning=0
speedcam_visualtype=1
speedcam_soundtype=1
speedcam_warning=1
speedlimit_warning_voice=0
speedlimit_warning_visual=1
speedwarn_tolerance=110
speedlimit_warning=1
[map]
auto_nightmode=0
3d_scale_carmodel=1
3dcarsizemin=3500 ;up to 5000
3dcarsizemax=7000 ;up to 10000
3dcarsizemul=20000 ;up to 30000
[speedcam]
usemio=-12,90,37,27
disable="_SUI", "_GER", "_AUT"
;speedcam_sound="!alert1"
enable_at_startup=1
[msnd]
msnd.start=0
msnd.version=0
Also you can add:
default_latitude=xx.xxxxx
default_longitude=xx.xxxxx
under [gps] for start location
