Results 1 to 7 of 7
Thread: How many sats can you lock on too?
    Variable Bitrate rgarjr's Avatar
    Jan 2008
    Covina, CA
    I know there's another thread like this one, but just wondering...
    I think I had been locked to 11 sats.
    Variable Bitrate Arrow's Avatar
    Feb 2006
    West Lafayette, IN
    http://en.wikipedia.org/wiki/Gps
    There's a nifty animation showing how many sats you can lock on to depending on their current orbit.
    I think the NMEA standard only reads 11 connections max at any given time anyways.
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    i don't know if you have been having problems, but on a side note sometimes xport causes me to lock on to less satellites, worth looking into if you've been having problems locking to satellites
    Feb 2006
    West Lafayette, IN
    I could be wrong, but I don't think xport could possibly cause you to lock on to less satellites. I'm pretty sure that the receiver handles the locking and then determines your position, then sends a string containing your position and the number of satellites it used to determine that position. You computer just displays this info on a map or whatever. If you are getting any information about how many satellites you are locked on to, then you are getting all of the info through xport.
    Mar 2005
    Rockledge, FL
    well this is just my personal expirience, but at at least 2 times this has happened to me, i started my car pc came out of hibernation, the gps antenna led blinked which means it's locked, but yet iGuidance nor RR would detect any satellites,restarted the pc nothing, checked the comm ports and they were correct, so i closed Xport and changed the comm port in iGuidance to the receiver directly and BANG 9 satellite lock immediately, rescanned with Xport changed comm ports again and then it started working perfectly.
    May 2006
    Calgary, Alberta
    Quote Originally Posted by Injector View Post
    Ya, that's a pretty common error, it's called PEBKAC.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Quote Originally Posted by Maheriano View Post
  1. Single Pulse to Lock and Unlock Using a mechanical latching relay
    By rotarypower101 in forum Hardware Development
    Last Post: 08-16-2006, 03:40 PM
  2. heat lock ups?
    By warnockm in forum General Hardware Discussion
    Last Post: 09-29-2005, 11:59 PM
  3. BU-303 only lock while booting
    By Goddy in forum GPS
    Last Post: 03-01-2005, 04:33 PM
  4. loosing lock on.
    By corsamel in forum GPS
    Last Post: 02-08-2005, 09:42 PM
  5. gps takes forever to lock!
    By aznblueeboi in forum GPS
    Last Post: 04-23-2004, 12:52 AM
