Results 1 to 5 of 5
Thread: GPS is way off
    Low Bitrate deeznudts's Avatar
    Oct 2007
    Trenton, NJ
    GPS is way off
    I thought this was a street deck problem at first. But now I think it's a problem with my GPS receiver. When I fire up my SD navigation 7 times out of 10 it says I'm in Las Vegas. Which is weird cause I live in NJ. I'm using the pharos GPS usb receiver which comes with streets and trips. The usb connections are all fine, all the com ports are set correctly, and it has a clear view to the sky because it's mounted right under my sunroof. Sometimes the thing works great. In fact it worked great for about 2 weeks. But now most of the time it doesn't. Has anyone ever had this happen to them? Maybe the thing is just busted, but if it's something simple I'd like not to shell out more $$. Thanks in advance for any response.
    Feb 2008
    I have the same problem and I canot figure it out, I am starting to think that is my receiver.
    Oct 2007
    Trenton, NJ
    What front end are you using? I'm running streetdeck 1.1.1.6. I found out the problem in mine. When I adjusted the driving speeds in SD it throws it way off. But when I reset them to the default it works just fine. Don't ask me why?????
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    What about trying another GPS program outside of SD?
    Or even a diagnostic program like SIRFDemo?
    Low Bitrate dmart23's Avatar
    Oct 2007
    just get a tomtom go 720...it will solve your problem
  1. How to setup iGuidance GPS for RoadRunner
    By MatrixPC in forum RR FAQ
    Last Post: 05-22-2009, 09:29 AM
  2. PPC Car GPS and MP3 mini How To
    By hotrod_nut in forum General Hardware Discussion
    Last Post: 02-25-2008, 02:24 PM
  3. Replies: 3
    Last Post: 08-10-2007, 05:03 PM
  4. few gps questions
    By fuctup in forum GPS
    Last Post: 03-02-2005, 02:40 AM
