Results 1 to 5 of 5
Thread: XPort and BU-353 Problem
    Variable Bitrate TeamRSX's Avatar
    Nov 2007
    Ottawa, Ontario
    Question XPort and BU-353 Problem
    I am just trying to set up my Bu-353 gps receiver and Iguidance 4 with Xport.
    I had it working the other day on another hard drive and was able to get a fixed location and everything worked, but now i cant seem to get to working.
    As of right now i am getting a solid light on the gps receiver which means its on but looking for signal.
    I can't seem it to find a fixed signal.
    I have installed the drivers that came with the gps receiver and before i used Xport i went into device manager to see what comm port the gps is going to use. Its comm 3 in device manager.
    So, then i installed xport and put the input at comm3 and output as comm4.
    WHen i open GPSInfo, it sees the gps on comm4 and outputs information, but the light on the receiver still doesn't blink and can't get fixed location.
    I have also made sure the baud rate is set to 4800 in xport, device manager for com3 and in GPSInfo
    Here is the output from GPSInfo.exe:
    01,,29,48,298,*74
    $GPGSV,3,2,12,26,20,173,,15,16,181,,30,14,252,,13, 10,032,*72
    $GPGSV,3,3,12,05,08,235,,12,07,221,,27,07,067,,25, 06,044,*74
    $GPRMC,154408.056,V,,,,,,,270308,,*2E
    $GPGGA,154409.065,,,,,0,00,,,M,0.0,M,,0000*58
    $GPGSA,A,1,,,,,,,,,,,,,,,*1E
    $GPRMC,154409.065,V,,,,,,,270308,,*2F
    $GPGGA,154410.056,,,,,0,00,,,M,0.0,M,,0000*50
    $GPRMC,154410.056,V,,,,,,,270308,,*27
    $GPGGA,154411.056,,,,,0,00,,,M,0.0,M,,0000*51
    $GPRMC,154411.056,V,,,,,,,270308,,*26
    $GPGGA,154412.064,,,,,0,00,,,M,0.0,M,,0000*53
    $GPRMC,154412.064,V,,,,,,,270308,,*24
    $GPGGA,154413.055,,,,,0,00,,,M,0.0,M,,0000*50
    $GPGSV,3,1,12,02,48,095,,24,41,293,,04,14,101,,29, 48,298,*74
    $GPRMC,154413.055,V,,,,,,,270308,,*27
    $GPGGA,154414.056,,,,,0,00,,,M,0.0,M,,0000*54
    $GPRMC,154414.056,V,,,,,,,270308,,*23
    Any help would be appreciated as i seem to be having problems with something. Hopefully its just a setting or something.
    Newbie japeeler's Avatar
    Nov 2007
    Jefferson, Texas
    Just bought a BU-353 and waiting for it to arrive next week.
    I have the BT-339 (Bluetooth) and have connection issues from startup mode, etc.
    So trying the USB version. I'll let you know if I figure something out.
    If yoy have a COM Port (9-Pin) on your Mobo, then I would try Changing the COM Setting of the GPS, if possible. (I do not know about that GPS receiver, yet) I can on my BT version.
    Change the INBOUND COM Port. Put the OUTBOUND COM Port to something like COM8/COM9. This way it is out of the way of your Serial port(s). They use COM3 & COM4 - If you have 2 Serial 9-Pin Ports)
    -=- TruckPC Progress -=- 98% Complete -=-
    -=- 2006 Ford F-150 Screw 4x4 -=-
    @@@@@@@@@@ <-- Planning Phase
    @@@@@@@@@@ <-- Purchasing (Never End)
    @@@@@@@@@@ <-- Construction Phase
    @@@@@@@@@@ <-- Installation Phase
    My TruckPC WorkLog @ MP3Car.com
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    since you are getting a solid light then it means that you do not have a fixed position (no lock) so it is not a software isue at all.. the bu353 does not need software to aquire a fixed position.. it is supposed to get a fix some seconds/minutes after you power it (plug it in to a usb port to get voltage) so most probably you do not have a clear sky above you (the glass in your car maybe??) move the unit in open air and see.
    Nov 2007
    Ottawa, Ontario
    You are correct.
    The first time i tested the gps i was bench testing in my basement and i was able to connect to 2 satellites. When i tried it a few days later it would not get a fixed location.
    When i brought it to my friends house to test everything i was able to get a fixed signal.
    So, was definately not getting a clear signal from my basement.
    Thanks for the help.
    Quote Originally Posted by Nomader View Post
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
