Results 1 to 4 of 4
Thread: sony skymap.
    Dec 2001
    my parents house ;-)
    sony skymap.
    is that a good or bad receiver? nmea compatible?
    Dec 2001
    oh its rockwell. but what difference are the types of receivers.
    is it bad to use one of those converters?
    Registered User
    Oct 1999
    If this helps I bought it in 98' off ebay.
    (I got the Pro ver.)They made two versions
    1)sony skymap travler - two connectors
    serial cable db-9,and power cable plug
    db-6 like the new style mouse's and keyboards use. GPS Signal Format(Rockwell)
    2)sony skymap pro - pcmcia card with a GPS Signal Format (etak/nmea switch)
    The remote allows you to:
    Zoom In and Zoom Out
    Pan any direction on the screen
    Center your vessel on the screen
    Switch between North and Course up orientation
    Right mouse click and select a menu item
    Access and navigate through the MarineMap menus
    Select menu items
    Dec 2001
    is the pcmcia unit a good one to use and can it be used with newer software?
    I can get a hold of the pcmcia one
