You're trying to run the patched exe from your road runner folder. Like Blue said, just put it in your iG folder, replacing to old one
All you need to do with johns patch is to replace your current iGuidanceUMPC.exe in the ..\Program Files\iNav\iGuidance\ folder.
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
MSI K9N6GM
1 gig RAM
8" Lilliput
Onstar GPS mod
XM
Visteon HDZ300
Hey Guys,
Here is what I did so far with all your tips.
I downloaded the new 4.0 patch from John's site
I then unzipped it in a new file folder on my desktop
Then I open the IG dir file and deleted the original icon.
Then I dragged the new one into the IG Dirtory file.
Now I have takeing a slide over to the xport splitter and confirmed that it found my port, it did, port 2. Then I chose two differnt ports under 9 to use with both my RR AND IG.
RR is set to port 3
and IG is set port 4
Now once all this was done i click on enable ports and closed it and it was down by the clock running in the background.
I then restarted the entire PC and check to make sure all ports were still set. and yes they are.
So I open up DFX and click on GPS and then clicked on Gas Prices and as luck would have it, I get an ERROR. Same error as above!!!!
So as you can see I have done everything I was told and I am still hitting a wall! Can anyone think of something I might be missing here? Any kind of tips would be great!
Thanks again guys!
Phil
do you have a gas folder in your rr folder? Its just for all the gas images, but just trying to think of anything else you might be missing..
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
Want to come over and have a look since you live here in Chicago as well? lol Yeah I just check I do have a folder in RR for gas. I am just bugging dude! Maybe it has something to do with the fact that my GPS weather Icon isn't working either? What do you think?
Phil
On that xport program do u have to always have it open or does it work on the background?
My carpc worklog
works in the background. I just set it once and it has always just worked from there on.
FYI, for anyone also having this problem
The problem was the fact that the rr folder name was one word "RoadRunner" and not "Road<space>Runner".
John as been notified of this and will be posting a new gasnav.exe in the next day or so to fix it..
DFX 5.1.1 Skin
Appstore Link
RRMedia
RRExtended
DFXVoice
