You just set the input port, set which ports you want to output, and click "enable" XPort will auto start on startup too.
Then in your GPS program tell it what port you want to use. In RR tell it the other port to use. Restart both, and it works.
Hello All,
I been searching and found alot on how I need to split my port to use my GPS with more then one program. I have rr and I am running DFX skin 3.0v, I have Iguidance 4.0 and what I been trying to do is just this.
When I go into DFX and click on my GPS button, takes me right to it, then I put in my destination and click the NAV button and the GPS does the rest!
However their is a button called "gas prices" and when I click it takes me to the neariest gas stations in my area also giving me the option to MAP IT. But when I click on the MAP IT the GPS is now suppose to NAV me right to that gas station but instead I get an error saying can't find location or something like that.
Here is the catcher, I know that this xport splitter is to be configured one port to rr and the other to DFX. Once this is done correctly, I been told and also read that I should then be able to click the MAP IT button and be NAV to my neariest gas station. I just don't know how to point them to two different ports.
PLEASE help me out here all I need is for someone to dumb it down for me, if you have a link or even pictures on how to config these two ports, that would be awesome!!!!!
Thanks Phil
1.9in x 2.9in -- 47mm x 73mm
ok i got that much however how do i know what port rr is on? thats where i am getting confussed. sorry to sound dumb I just don't understand clearly i guess. So where do i find out what port rr is running on? and where do i find where IG is running on?
Open RRConfig, in GPS section that is where the port is as it always has been.
Open iG (outside of RR), and in one of the dropdowns there is a GPS section, choose the port as it has always been.
Ok cool thanks, however I just did that and i keep getting the same error. Could it be that I might need to download John's patch? If so I have downloaded it, but when I go to install it, that also gives me an error. I know I am probably being a pain in the *** lol i am very sorry, i just don't know how to correct this. Thank you for your patients and help.
Would a screen shot of the error help you any better?
Phil
I have attached my error that keeps coming up after I click on the MAP IT in gas prices screen. THANK YOU.
Phil
Things that you need to use map it.
1. GPS working correctly (ports)
2. Johns 3.0 or 4.0 iG patch (adds gps coods back into iG)
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
Talking with BlueZX, I think I may have narrowed it down. Make sure you have the exec.exe file in the Root Road Runner folder. This is needed for the script to work. This is included with the Road Runner install, so it should be there. It's possible you did a custom install, and its not where it should be.
My Fiero Build Thread
Thanks Guys, Hey Bluezx,
I have the exec.exe file in my root file like john asked me to make sure i had. I also tried to dowload and install the patch. but i keep getting an error. Do i install this by doubling clicking on it, or do i move it to a file folder in the root of rr? Not sure why I keep getting this error when i try to install the patch. I kinda thought that might of been the problem wasn't 100% sure thought.
Again many thanks for the help these last past weeks.
Phil
Here is the error i am getting with the patch from Johns download.
