Results 1 to 5 of 5
Thread: holux 236 gpslim .. issues charging / using bt
    May 2006
    Ok so this unit works fine via bt. but I wanna have it charging all the time via usb.. the only issue is my pc keeps popping up with usb device not recognized.
    anyone have a solution ? dont wanna buy a usb cable from holux..
    Newbie warrenj38's Avatar
    Mar 2007
    Alberta
    I am afraid you need to buy their cable, it has weird wiring.
    If you only knew the power of the dark side.....
    May 2006
    yah.. i think ill just hardwire it with my usb phone charger... but my issue now is that I have to have it on all the time or road runner slows to a halt looking for my receiver... :-(
    The mini-B "USB" plug on the 236 is not USB at all... you can only charge with that port if you don't have the Holux USB cable.
    FLAC Marvin Hlavac's Avatar
    May 2005
    You don't need the special USB cable from Holux, if you only want to charge it via USB. Charging will work just fine with any USB cable. You will be able to use the Bluetooth function to connect to your GPS software.
    There should be a way to kill the "usb device not recognized" message for good - not sure how, but there must be a way :-).
  1. Holux BT external antenna
    By hoodlum in forum GPS
    Last Post: 11-08-2006, 06:52 PM
  2. Moto SLVR + phoco / BT or Cable
    By StayFocusd in forum PhoneControl
    Last Post: 05-25-2006, 11:01 AM
  3. Replies: 8
    Last Post: 04-19-2006, 12:19 PM
  4. Replies: 1
    Last Post: 03-07-2006, 10:21 PM
  5. Mot V551 BT - PhoCo and/or Headset
    By Zogg in forum PhoneControl
    Last Post: 09-29-2005, 12:49 PM
