are you using a legal copy?
map data and text to speech files are on the dvd, just copy them to your inav folder and it should work.
Normally when i have software issues searching a few forums provides me with the answer. In this case i have search far and wide, tried almost every installation combination possible but i still cant get iGuidance working.
Lets start from the beginning. I have had iGuidance 4 on the laptop for the last 3 weeks. everything was working fine. it was running off an iso as my dvd drive doesnt do well in the car. i decided to look around in it and see if i couldn't change the text-to-speech voice....this was a mistake. i didn't alter and files but iGuide didnt seem to care. i try to open iguidance and i get "Text-to-speech Files not found. Please make sure the Map Data and Text-to-Speech Files are properly installed"
Since then i have re-installed it several times, copied the iNav Iguidance folder directly to c:, rebooted god knows how many times.
I am installing to the default location (C:/program files/inav/iguidance), installing from disc, installing from iso, running from disc, running from iso, copying the iNav iGuidance folder (which by the way i did NOT have to do originally to get it to work).
i have even went as far as to restore my registry from two days ago (when the problem started)
still nothing.
i need help!
and it the whole iNav folder needs to be in [OS DRIVE]:\iNav and no where else.
1.9in x 2.9in -- 47mm x 73mm
I think I had trouble with the CD in. Unmap the iso and see if that works.
uninstalled everything. deleted the iNav dir. reinstalled As Admin. (vista)
ran iGuidance as admin.
everything is working fine.
