Results 1 to 8 of 8
Thread: iguidance v4.0 problem
    Apr 2008
    i just installed iguidance 4.0 on my laptop,and when i run the program it says it cannot load find the map files.i tried too move it around the iguidance folder in c: but it still doesnt work.any ideas what too do?
    Variable Bitrate hailrazer's Avatar
    Mar 2008
    Columbus, Georgia
    Quote Originally Posted by cadogan18 View Post
    This thread tells you how to install it with the maps on the harddrive.
    Iguidance 4 install location
    Apr 2008
    ok thanks ill try that out.it says you should run it off the d drive.that doesnt make sense really cause the d drive would be the cdrom drive.its just confusing too me.
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    look in the cd drive, and copy the inav or igudance i can't remember folder to c:\
    Apr 2008
    ok,ill see if that does it.
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    reason why they say D:\ directory is because most people in this forum has 2 partition. C parition which has your windows files and D parition which is where most people put there music. If you have a cd rom also this would be your E:\.
    But to me it seem like you only have one parition which is C parition so you will put your map files in C:\Inav
    Apr 2008
    i just stuck it in the c: directory and it works.thanks
    Jun 2006
    Houston, TX
    That great to hear
  1. iGuidance TTS problem
    By teddyboy in forum GPS
    Last Post: 03-20-2008, 11:52 AM
  2. iGuidance and Volume -odd problem
    By sparkyssb in forum Road Runner
    Last Post: 01-31-2008, 10:01 AM
  3. Problem Installing Mapps (Iguidance)
    By tratpop in forum GPS
    Last Post: 04-15-2006, 03:08 PM
  4. iGuidance map loader problem
    By Sonicxtacy02 in forum GPS
    Last Post: 01-07-2006, 08:47 AM
  5. Iguidance reroute problem?
    By samc in forum GPS
    Last Post: 10-02-2004, 11:49 PM
