Results 1 to 2 of 2
Thread: IG4 crashes on certain map areas. Corrupt map?
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    I was driving north from Calgary, Alberta (Canada) to Red Deer on HWY2 with IG4 running as my navigation and it crashed about 30km from Red Deer. I relaunch the application and it crashes immediately when the GPS signal is found. I drove for a few kms before IG4 would launch again without crashing.
    I am suspecting there is something wrong with the map that causes the application to crash when the certain areas are being viewed. Even when I am not driving and simply scrolling the map to those areas, the application will crash. I have noticed there are certain other areas around Red Deer that will also crash the application. Not sure if this happens to areas around other cities. I have never had any problems viewing the map from within the city.
    Has this happened to anyone? Or maybe someone knows what can be done?
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    something happen when you copy that part of the map. Recopy you map files
  1. IG4 map and position accuracy
    By hari-bhari in forum GPS
    Last Post: 02-08-2008, 01:07 AM
  2. Replies: 10
    Last Post: 08-22-2007, 06:10 AM
  3. Map Monkey crashes after a while
    By superbowl in forum Map Monkey
    Last Post: 09-14-2005, 09:29 PM
  4. Delorme Street Atlas 05 quick review
    By cash_Money in forum GPS
    Last Post: 12-13-2004, 08:31 PM
