Results 1 to 5 of 5
Thread: Garmin etrex legend and CoPilot 2k2
    Oct 2002
    Greensboro, NC
    OK gang..question for all of you GPS gurus out there...i have tried a search but couldnt come up with much info about this.
    I hooked up the etrex to copilot and it worked...recognized the receiver...yadda, yadda....and got the "CP only works with the CP reciever" message.....no biggie right?
    I read that the Garmin sends too many signals out for CP to understand...and i guess my question is how do you hack the etrex to make it send the correct signals to CP?? I know it can be done with the Garmin35 but I could find no info on the etrex
    Thanks!
    DigitalDub
    1200 mhz duron/ 384m pc133/ 6.4 gig for OS / 75 gig storage/ 32 meg Nvidia Geforce2 wit TV out / onboard sound / GPRS / 7" digitallww flip out / X10 Mouseremote / 255w inverter (temp)
    Audio
    Nakamichi CD-45Z HU / Monsoon amp and 8 speakers
    FLAC cproaudio's Avatar
    Aug 2002
    so cal 2 hours from everywhere
    http://www.garmin.com/support/download.html download the right utility and select only GPGGA, GPGSA, GPRMC and GPGSV. Before you jump the gun and get all excited, it's probably not gonna work. Copilot software looks for the rockwell binary which the Garmin doesn't send. I've tried so many settings on my Garmin GPS 16. you can also read this thread
    Copilot lose GPS connection
    Oct 2002
    Greensboro, NC
    downloaded the updater for the legend but when i open it up, it tells me that there are no updates available...cant get into it to make changes
    any other ideas?
    DigitalDub
    Audio
    Aug 2002
    Mine has an updater and a configurer. I used the configurer to change the setting. Anyway it most likely won't work with Copilot. You may want to try Rand McNally serial GPS receiver. It works with Copilot. I read somewhere that Navman GPS also works. Copilot Nav looks for GPS via COM ports so the USB version might not work.
    Oct 2002
    Greensboro, NC
    Yeah, I looked around for one of the rand receivers, but no one sells them anymore...even the travel store only sells the Navman....looked on Staples site and they have them, but not in stock and they wont be getting any in according to them. I looked on ebay and there is one...
    If i get the Navman I will get the serial version.
    DigitalDub
    Audio
