Results 1 to 2 of 2
Thread: CF GPS Card on Commell LV-671 - help
    May 2008
    Hi,
    I have a Holux GM-270 and I cannot get XP, LinuxICE or CentOS to recognize the card. The card does still work in another device so I can verify that it is functional, but I would like to use it on the computer for obvious reasons. The PCMCIA controller also appears to be working correctly.
    Has any one had luck with this combination? Perhaps there is something I am missing in the BIOS?
    I did change the CF Address setting (JCFSEL) jumper on the mobo from master to slave
    any help appreciated.
    May 2008
    Hello frndrfoe,
    It simply won't work that way. the CF slot is really an IDE-only slot. It is only wired to the IDE controller and not to the PCMCIA controller at all, so any IO cards won't work, only CF flash cards (up to any size, that is an advantage though)
    You will need a PCMCIA--> CF adapter to get the card working, and plug it in the PCMCIA slot. That should work, if supported at all.
  1. Replies: 106
    Last Post: 02-19-2015, 09:23 PM
  2. Replies: 65
    Last Post: 10-13-2009, 07:51 PM
  3. Can't hibernate after transfer to CF card
    By blkwrx in forum Operating System Optimization
    Last Post: 02-08-2007, 08:47 AM
  4. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 06:54 AM
  5. Autorun CF card on insert???
    By Ill1 in forum General MP3Car Discussion
    Last Post: 07-09-2004, 10:19 AM
