Results 1 to 6 of 6
Thread: Bu-353 software? Maps?
    Apr 2005
    I have a bu-353 antenna, not installed yet, but it's going in tomorrow. I found the drivers, but where can I find software?
    What is a good software that will work with centrafuse or road runner?
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by MAZDABOY View Post
    BU-353 = GPS Receiver
    Maps = Software that use GPS Receiver for position
    Neither are dependant on the other. You can use that receiver or a pharos unit, or a bunch of other units that output NEMA info.
    So you need to buy GPS software such as iNav's iGuidance, or Microsoft's Streets & Trips, or Destinator, or Map Monkey, or a bunch of others.
    Usually $50 to $200
    1.9in x 2.9in -- 47mm x 73mm
    Apr 2005
    Damn I thought I was going to get away with this for cheap. Are there any free gps software?
    Here is an odd question, the gps in my other car is a cheap0 with the sd card with all the maps. Can I just copy over all those maps or no? My guess is probably not.
    Mar 2006
    None worth using.
    No.
    One reason being map data and interpreting data is different. Not all formats are the same. Maps costs money, and the interpretation costs money. When you buy GPS navigation software, it comes with both maps and the interpreter. Your interpreter is on your basic cheap device. The maps are on the SD card.
    Second reason being that it is piracy which is illegal because it breaks your EULA with the device manufacturer.
    Elsewhere
    If you intend on using Centrafuse, it has the navigation and maps with it.
    Granted, you're paying for Centrafuse, and part of the cost is for licensing the map data and navigation engine.
    How about the Wiki?
    Nov 2008
    Have you considered the CarPC version of Trapster? It does not do routing, but does show current position and custom POIs on a Google map. Plus, it's FREE
  1. Replies: 2
    Last Post: 07-14-2008, 03:14 AM
  2. WTB: BU 353 GPS receiver
    By penny1jordan23 in forum Classified Archive
    Last Post: 07-06-2006, 09:52 PM
  3. Can't get the BU 353 to work with Destinator plugin
    By inniss777 in forum Centrafuse
    Last Post: 11-24-2005, 03:56 PM
  4. Looking for GPS software & maps for Clarion AutoPC 310C
    By Jerm in forum Classified Archive
    Last Post: 08-02-2004, 09:22 PM
