Results 1 to 10 of 14
Thread: Best GPS USB reciver - $$ is not an object
    Nov 2008
    Of course it allways is but we could spend up to $200 on the GPS reciver in this project
    _
    Mar 2004
    Little Elm, Texas
    This really is a ridiculous question.
    Why don't you try spending some time reading in the forum rather than just asking someone to tell you. Better yet, why don't you just go and purchase a complete solution from one of the many CarPC retailers. If you don't want to take the time to understand why you are going with each and every solution in your set-up, then it's the best option.
    Jan Bennett
    Nov 2008
    I'm not purchasing compleet solution cuz none of the compleet once have many things I require - full size PCI slot for a Lynx card, solid state HD, bit perfect software, etc......
    FLAC WuNgUn's Avatar
    Sep 2007
    GPS mouse is a good one...available at the store!
    Nov 2008
    GPS Mouse - lol
    Nov 2008
    Oh - you meant G.Mouse - BT353 - kind of on top of my list
    Was wondering if anything outpreforms it
    Constant Bitrate mx270a's Avatar
    Aug 2003
    Iowa
    Quote Originally Posted by LCat View Post
    I'd go with the Trimble 252. They start at $3000 for the WAAS version, $5000 for OmniStar XP/HP capability, or $7000 for dual frequency RTK support. Position updates at 10 Hz with an accuracy of under one inch.
    If you can wait a couple months, I've heard they are coming out with a new version that will probably add GLONASS support.
    You did say $ is not an issue.
    Nov 2008
    Well - if you read this post you would have seen - not an issue up to $200. Now if we were talking about pice of audio eqipment - well you just mentioned about 1/8th of the retail of my audio system Also not sure why knowing my position to an inch would help me on the road. Precision is good but I do not think we need it to more then to couple of feets at best. Now speed of aqusition, relaiability in the city, overall relaiability - thats important
    _
    Mar 2004
    Little Elm, Texas
    This ALL depends on how well you want it integrated. Again, a few reads through a few threads will tell you a ton about which GPS receivers are top on people's lists.
    If you want it 100% integrated, the GPS mouse isn't the way to go.
    Jan Bennett
    Constant Bitrate bridqer's Avatar
    Nov 2003
    Maryland/Arizona
    After killing a few gps mouse receivers with wet weather and usb problems, I use a Garmin OEM 16 HVS High-Sensitivity $93. Gamin also has the Garmin GPS 18x 5Hz High-Sensitivity for $140 for something more accurate.
    '99 F-350 Crew 7.3L~'02 F-350 Crew 7.3L~ '04 Dakota SLT+ 4.7L
    MII12000opus120~MII12000opus120~MII10000opus150
    NA~Senao dual 7.4 ant~Orinoco Gold
    Pioneer~Pioneer~PG Octane-R R5.1MT
    Xenarc, Rikaline6010, Garmin OEM16 HVS, CoPilot10
  1. Replies: 85
    Last Post: 07-27-2011, 07:27 PM
  2. garmin mapsource and usb gps mouse
    By thecrow in forum GPS
    Last Post: 09-26-2006, 03:24 PM
  3. earthmate usb gps with MS Streets&Trips?
    By liquid_smoke in forum GPS
    Last Post: 11-27-2004, 09:45 PM
  4. D3 with USB GPS after HIBERNATION
    By BOND007BE in forum Map Monkey
    Last Post: 11-26-2004, 02:54 PM
  5. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 01:25 AM
