Results 1 to 7 of 7
Thread: program to prime GPS right when the computer starts
    Aug 2008
    Been reading around but couldn't find the answer for this.
    Is there a program that would run and lock to GPS satellites right when windows log on? So that my position is available whenever I run NAVI; instead of running NAVI when I need it and wait for a fix on the satellites.
    I'm doing the Centrafuse trial right now, and I notice that GPS receiver will only begin to get a fix when I click the Iguidance button. But then I would need to wait for the satellites to lock into position.
    Thanks.
    Aug 2008
    wait a min.......I think I found my answer....XPort....is this it?
    Variable Bitrate rgarjr's Avatar
    Jan 2008
    Covina, CA
    The GPS device should start locking satellites whenever it receives power from the USB.
    My carpc worklog
    Aug 2008
    I have a bluetooth GPS receiver though.
    FLAC Marvin Hlavac's Avatar
    May 2005
    ...yes, xport, or gpsgate, should do the trick.
    Constant Bitrate tom_rosenback's Avatar
    Oct 2006
    Finland
    Shouldn´t the GPS receiver get "fix" position (cold start) a short while after it has been powered up? At least my USB receiver does, without needing to start the nav software (or XPort).
    What I would like to have is that it would get fix position directly after power up, like some handheld GPS´s do, also some Nokia phones have this, I think it is called AGPS on them.
    Newbie CabrioBob's Avatar
    Jul 2008
    netherlands
    Quote Originally Posted by tom_rosenback View Post
    It may be possible to create system where your GPS mouse stays powered on even when the PC is powered off.
    With a solar panel, chargable batteries, a relay and the GPS mouse.
    PC OFF mode :
    Relay cuts off the connection between the GPS mouse and carputer.
    Daytime (sun is shining) : solar panel provides power to the GPS device and charging the batteries.
    Night time : batteries are charged and provides power to the GPS mouse.
    PC ON mode :
    Relay cuts off connection between GPS mouse and batteries / solar panel, batteries will still be charged by the solar panel (or: batteries charged by carputer).
    GPS mouse is operated by carputer conventionally.
    The above are only thoughts I have had in the past, don't even know if it's doable
    but small solar panels are affordable these days so maybe someone else might want to dig deeper into this.
    solar panel example
    (assuming GPS mouse will also operate @ 5.5V)
  1. RR gps program with Australian maps??
    By Moby58 in forum Road Runner
    Last Post: 11-23-2008, 08:35 PM
  2. Replies: 13
    Last Post: 01-15-2008, 05:29 AM
