I use sygic and it works great. Everything is installed on the pc so no dvd required.
I use the BU-353 which is a usb gps reciever and have no problems.
I run all this on my dev pc which is a acer aspire and on my shuttle based carputer.
I have just purchased an Acer Aspire One, Win Xp and 160gb hard drive, built in mic.
I would like to use this as my gps/mapping system for travel.
I have used older versions of Streets & Trips, and have an original Tom Tom.
My questions are:
1. Do any of the mapping programs take voice commands from the laptop to control functions?
2. Can they be installed on the Acer in total and not require a DVD drive to work?.
3. What gps receiver do you recommend, and should it be blue tooth or usb?
4. What software package do you recommend. I have been reading the Iguidance reviews and it sound interesting.
In advance, thanks for your help.
The one question I have for YOU is this-
what size display?
A 10" screen is plenty big enough for any of the computer software out there to be usable. Smaller... yeah, not so much. I have a 7" in my car and a netbook with an 8.9" and both are too small for my normal laptop software (Delorme) to work very well imo.
I have found that Garmin Mobile PC works very well on small screens, but has a few disadvantages-
no on-screen keyboard
activation policy that makes it very difficult to migrate the software to a new system if you upgrade.
One of my BU-353s died, so I did get one of the Garmin bluetooth GPS sensors as well, and have to say that I am rather fond of the convenience of THAT, though battery needs to be charged every few days of use.
I have no experience with voice command nav, as I don't use that. Or even the spoken directions..![]()
Hi jgaylor,
1. As far as I know only DeLorme Street Atlas has the built-in voice command function. There may be user created add-ons for other programs that achieve the same.
2. Yes, you may install programs on your DVD-less laptop. You can do it by networking it with another computer that does have a DVD drive, or by using an external DVD drive for the installation. Or you may just copy the content of the DVD drive to a memory card, or memory stick, and then run the installation from there.
3. If you don't mind the cable going from your laptop to the GPS, then USB GPS is a good choice. Otherwise get a Bluetooth unit.
Globalsat USB GPS BU-353 is a very popular unit on this forum.
4. Yes, iGuidance is very good. There are a few other programs, too. Each has its weaknesses and strengths.
acer one aspire 8" screen
