Results 1 to 5 of 5
Thread: Xport Disappearing ports problem.
    Sep 2003
    Thousand Oak, Ca
    When I installed xport I didn’t realize it auto started on it own so I put a copy of it in the startup folder. I realized my mistake after a little reading and its working great now. But now the ports I started out with (ports 4&5) no longer show up in the output port select pull down. I tried uninstalling Xport and deleting the Xport registry entry then reinstalled Xport. But still no option for port 4 or 5. Where does xport store this info?
    Mike
    FLAC WuNgUn's Avatar
    Sep 2007
    Just output to different port numbers and reconfigure your devices to use these new ports...
    Possibly something you instaled took those ports, i.e. my BT dongle ALWAYS takes COM3 and 4...
    Sep 2003
    Thousand Oak, Ca
    This happened twice so I’m missing 4 ports. Each time it happened only the ports that xport was using disappeared that’s why I believe it’s xport. Port 2 is the only one left below 10 and I’m using that with IG because it won’t remember any ports higher than 9.
    It’s working great now but it would be nice to get the lower ports back.
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    XPort doesn't save the information anywhere, but it does allocate them in the port arbiter. Anything can go wrong though, and it fails once and leaves those allocated. Hitting the Scan button would fix it. I actually changed all that a week ago so that it doesn't rely on the info but still keeps it up to date. I replaced 1.28 with it on my site and didn't bump the version number.
    Sep 2003
    Thousand Oak, Ca
    Thanks Curiosty, that did it.
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  2. xport + AyAy Sir crash problem.
    By Punky in forum GPS
    Last Post: 07-24-2008, 02:30 AM
  3. Usb ports on Morex Case problem
    By volum3rider in forum General Hardware Discussion
    Last Post: 11-14-2005, 07:25 PM
  4. had an all day (9 hr) problem at work....
    By wizardPC in forum Off Topic
    Last Post: 10-20-2005, 12:50 PM
  5. Replies: 13
    Last Post: 07-15-2004, 01:07 AM
Tags for this Thread
