Page 11 of 32 FirstFirst ... 23456789101112131415161718192021 ... LastLast
Results 101 to 110 of 318
Thread: GPSTracker on home server
  1. #101
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by Sonicxtacy02 View Post
    i got this installed per your instructions. The funny thing is when i launch the client app it sends a single point to the server.. but subequent points are not sent... the debug says the server isnt pingable... even though the server clearly is because one point has been sent. This happens each time i start the client app... one point uploads.. then nothing. Any ideas?
    The way the app works is to try to send data when a network chnge occures i.e. everytime you get a new network connection. It checks to see if the network is an internet connection by trying to connect to http://www.microsoft.com/. If this passes then it looks to see if you've allowed the server to be pingable. This is set in the ini file. If it is then it trys to ping. If it recieves a response then it trys to send the data if not then it fails.
    I think the debug message your seeing is the setting from your ini file as I default it to false.
    I think whats happening is the client has sent its message, which the server has recieved (hence the one point) but the the server message sying its recieved the data is not being returned to the client. The client then goes into the no connection mode and waits for the specified retryperiod.
    So the question is why does it think its not sent the data when it has.
    Does the client say a current time for the server updated label?
    Does the client seem to hang for a long time?
    try setting your tracking period and retry period smaller. Say 10 secods and 15 seconds. That way you may see more points. It wont have solved your problem but it will narrow it down.
    I assume that the server can see the client. By this I mean can it respond. have you got a firewall that will stop it from responding?
    Can you send me your debug file to take a look.
    I could add some extra debug and send you a special version if you pm me your email address.
  2. #102
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    Quote Originally Posted by lambosprit View Post
    Yes the initial connection specifies the time the server updated
    No the client's CPU doesnt raise and i've seen no signs of it hanging
    Its very possible i'm missing a setting or something.. but there shouldnt be any firewall installed on my carPC and i've got the ports handled on the server. I guess i should check if windows firewall on the carpc is blocking the connection. In any event.. my debug log is attached and my email is sonicxtacy02@gmail.com. Thanks for your help
    Live mp3Car Facebook Chat
  3. #103
    lambosprit's Avatar
    Sep 2006
    UK
    can't see any debug log. Am I missing it somewhere?
    Some other things came to me.
    Does the client say connected at the bottom (you need debuglevel of 5 for this to show).
    Have you changed the timing settings or are they still 30 and 60?
  4. #104
    Woodbridge, VA
    Blog Entries
    32
    ah i forgot to post the log while i was at work. My appologies. I did play around with it some more and i got it working. I dont know if it was turning off windows firewall or reducing the timing options but its working great now
  5. #105
    lambosprit's Avatar
    Sep 2006
    UK
    Great. Seeing as your the only one following this at the moment I'll update you on upcomming stuff.
    Personnally I have more than one user on my server machine. What I'm finding is that if the user logged on isn't the one running the software it doesn't track anything...obvious I know. But to solve this I'm working on changing the server to be a service and adding a gui to display whats happening when required. this has a problem though in that its very difficult to have a gui on a service. So if an alert or sos comes in there is nothing displayed.So I then need to make a tray app that will show an alert.
    So I'm converting the current server to a service + gui app + tray app. What do you think? Is it a good idea?
  6. #106
    Woodbridge, VA
    Blog Entries
    32
    its a very good idea.. in order for the program to be useful the server needs to be running at all times so having it convert to a service makes sense.
    Have you given any thought to making the client app an RRExtension plugin? Seems it would be pretty easy to do just convert the GUI text to labels and create indicators for connection status and such. It would be nice to view this stuff inside of a skin and using RR would allow the client app to be controlled at hibernate/resume (not that i've had any issues with them yet).
    I'm gonna get a skype account today and test those features... i'm basically trying to justify having a data card here
  7. #107
    lambosprit's Avatar
    Sep 2006
    UK
    check out my rrskype plugin.
    I changed the client to right scale for RR but not sure whether the effort is worth what you'd gain by making it rr specific. May rethink this after I have the service working ok.
  8. #108
    Woodbridge, VA
    Blog Entries
    32
    I'll definitely check out RRskype.
    If you wish to create an extension plugin i would be happy to port the standalone for you depending on its written language (i can handle vb6, .net, and c#) I'll also make sure to keep it updated with your changes if need be. No rush or pressure... just keep it in mind. Thank you for another great app!
  9. #109
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    Quote Originally Posted by eigenVector View Post
    I've written a similar app in C# for my Windows Mobile phone. It makes use of SQL Server CE 3.5 to store the data......
    got an idea for this... what about the car sends the data to an sql server?would of course require internet access... but would be nice to have as an option for those of us that has mobile broadband dongles
  10. #110
    Oct 2008
    Odense, Denmark
    Quote Originally Posted by TimmyM View Post
    I use webcamXP running some security cameras.
    another crazy idea as i read along, while sending data to the server why not have an option to upload photos from a hidden cam inside the car?
    i could think of a folder on a webserver with photos, sql server for gps data, and then some mainpage for it's current location and speed etc... and then a link for each time it has broken geofence. when outside geofence it should upload pics each 30 sec.. or maybe leave it to the user how often...
  1. it works.. auto syncing when you arrive home
    By collegeboyslive in forum General MP3Car Discussion
    Last Post: 11-29-2007, 07:36 PM
  2. Home
    By stasik-a4 in forum Map Monkey
    Last Post: 06-01-2007, 01:55 AM
  3. Image server
    By qwertylol in forum Software & Software Development
    Last Post: 01-10-2007, 04:02 AM
  4. MS Server 2003 help
    By nappyjim in forum Off Topic
    Last Post: 05-25-2006, 05:22 PM
  5. Replies: 2
    Last Post: 10-08-2005, 04:01 PM
