Page 15 of 32 FirstFirst ... 5678910111213141516171819202122232425 ... LastLast
Results 141 to 150 of 320
Thread: GPSTracker on home server
  1. #141
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by Cerberus View Post
    Flippinek.. I got away for a few months and when I get back yr on Version
    Three already! Nice work!
    I still have the original in the car. I shall have a download of V3 and see whats
    what.
    C
    welcome back. Some tasty new features for you to try. If you have a go at mapping please tell me so I can see if it works. So far either everyones disabled it or it doesn't work and I dont know which it is.
  2. #142
    Mar 2005
    Weird I posted a response and it disappeared. Twilight zone here. I will try again.
    Lambo I wanted to double check something quickly with you before you were to waste any time on this.
    Quote Originally Posted by lambosprit View Post
    It should make no odds. The client updates tracking data at a user definied interval that depends on whether its in the alert mode (every 2 secs), connected to the server or not connected.
    Does that mean it only logs data every 2 seconds? Or that the data is sent every two seconds to the server? I did test my unit and it worked at 5Hz and recorded some nice and smooth GPS tracks with some other software, but I had to manually start it, choose a file name, and stop it. Obviously I would rather use your software.
    Does it matter what NMEA sentences we use? I have my unit only sending $GPGGA and $GPRMC sentences to save bandwidth and make data sorting easier in the future.
    Can you give me some hints about how to install it only on a client machine?
    In the first post it says something about different directories. does this mean I could just install the client and server both on the carputer then have the data saved in an SQLlite database there?
    Thanks for you help
    *crosses fingers this post doesn't get deleted too*
  3. #143
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by sxott View Post
    The client sees every message the gps unit sends but it only logs data to the database for the time periods you select.
    If in alert mode its every two seconds but for the other two its upto you. In your case with no server you'll just set the tracking period and retry period to the (same) seconds you want.
    I look at GPRMC,GPGGA,GPGSA.
    You need the GPGSA to verify how accurate the gps location is HDOP in particular.Without this no tracks will be created as the app will allways assume that the track is to low in accuracy.
    To install without the server do the following.
    Install the client on your carputer. Tick the mapping & tracking boxes (the proxy server is not implemented yet).
    When you get the ini file settings screen make the internal and external ipaddress 127.0.0.1.
    Make the com port 1234 (just a 4 digit number, its not used)
    make the macaddress something that looks like a macaddress (again its not used)
    make the SSID any string (i.e. lambo).
    Set the client user to a name for your car.
    set the tracking and retry period to the time you want each track to be taken .Make them the same value.
    Set the gps settings to your gps devices settings (the latest version I have here automatically detects this)
    On the next screen set the min number of points to be deleted when collecting mapping data. This is to protect your start and end location for privacy reasons.
    Leave the manual / auto setting on 1. This way the mapping data will be sent when ever you have a network link. If you'll never have a link then set it to 0 but then you'll have to manually export the xml (just click on the client button ) and then upload it to the mp3car.com ftp site.
    probably missed something but any problems just post or pm.
    edit: I did forget.
    You ONLY need to install the client not the server.
  4. #144
    lambosprit's Avatar
    Sep 2006
    UK
    22 downloads and no feedback. I can't improve things if nobody tells me whats wrong (if anything).
    Also nobodys uploaded any mapping data. Is this because you've all switched it off or because you can't get it to work? I'm willing to help any one who asks for help.
  5. #145
    Mar 2005
    I haven't had a chance to do it yet lambo I will give you some feedback when I do.
    I was debating waiting on a new copy of winXP. This is for a project, but I used a personal copy to save time. I did not activate it yet and wanted to get the organizational copy installed.
    edit:
    BTW no one happens to know what how well USB wifi adapters work do they? I don't know if I can get a card into the case it is super tight. I would probably be able to get a USB cable and place the adapter somewhere with better reception to.
  6. #146
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    i almost had my car pc perfect setup on the bench... but then i screwed it somehow... will return later today when i get it running... also need to move the gps closer to the windows as it cant get a fix at the moment
  7. #147
    Oct 2008
    Odense, Denmark
    got the tracker installed but there are a few problems that i cannot crack..
    the server part is ok but the labels are off when the window is maxxed:
    the client is getting good gps fix(garmin set to use com6, RR com7 and the tracker com8):
    but the client is not working, i get an error like this:
    The box says this:
    Code:
    Se slutningen af denne meddelelse, hvis du vil have detaljer om,
    hvordan du starter JIT-fejlfinding i stedet for denne dialogboks.
    ************** Undtagelsestekst **************
    System.ArgumentException: Stiens format er ikke gyldigt.
       ved System.IO.Path.NormalizePathFast(String path, Boolean fullCheck)
       ved System.IO.Path.NormalizePath(String path, Boolean fullCheck)
       ved System.IO.Path.GetFullPathInternal(String path)
       ved System.IO.DirectoryInfo..ctor(String path)
       ved WindowsApplication1.DatabaseProcessor.WriteData(String time, String user, String lat, String lng, String spd, String trans, String tablename)
       ved WindowsApplication1.GPSClient.ConnectionTimer_Tick(Object sender, EventArgs e)
       ved System.Windows.Forms.Timer.OnTick(EventArgs e)
       ved System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
       ved System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Indlæste assemblies **************
    mscorlib
        Assemblyversion: 2.0.0.0
        Win32-version: 2.0.50727.3603 (GDR.050727-3600)
        CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
    GPSTrackerClient
        Assemblyversion: 3.0.3565.30116
        Win32-version: 3.0.3565.30116
        CodeBase: file:///C:/Programmer/GPSTracker/GPSTrackerClient.exe
    Microsoft.VisualBasic
        Assemblyversion: 8.0.0.0
        Win32-version: 8.0.50727.3053 (netfxsp.050727-3000)
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
        Win32-version: 2.0.50727.3053 (netfxsp.050727-3000)
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Runtime.Remoting
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    System.Configuration
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
        Win32-version: 2.0.50727.3082 (QFE.050727-3000)
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
    System.Data.SQLite
        Assemblyversion: 1.0.62.0
        Win32-version: 1.0.62.0
        CodeBase: file:///C:/Programmer/GPSTracker/System.Data.SQLite.DLL
    System.Data
        CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
    System.Transactions
        CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Transactions/2.0.0.0__b77a5c561934e089/System.Transactions.dll
    System.EnterpriseServices
        CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.EnterpriseServices/2.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
    CustomMarshalers
        CodeBase: file:///C:/WINDOWS/assembly/GAC_32/CustomMarshalers/2.0.0.0__b03f5f7f11d50a3a/CustomMarshalers.dll
    mscorlib.resources
    System.Windows.Forms.resources
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_da_b77a5c561934e089/System.Windows.Forms.resources.dll
    ************** JIT-fejlfinding **************
    Hvis du vil aktivere JIT-fejlfinding, skal værdien jitDebugging indstilles
    i afsnittet system.windows.forms i konfigurationsfilen
    for programmet eller computeren.
    Programmet skal desuden kompileres med fejlfinding
    aktiveret.
    Eksempel:
    <configuration>
        <system.windows.forms jitDebugging="true" />
    </configuration>
    Når JIT-fejlfinding er aktiveret, bliver alle ikke-afviklede
    undtagelser sendt til den JIT-fejlfindingsfunktion, der er registreret på computeren, i stedet for
    at blive afviklet af denne dialogboks.
    DEbug:
    Code:
    31-10-2009 11:37:10:Info   : GPSTracker client version :3.0.3565.30116
    31-10-2009 11:37:10:Debug  : C:\Programmer\GPSTracker\gpstracker.ini
    31-10-2009 11:37:10:Info   : External Server IP address is ************
    31-10-2009 11:37:10:Info   : Internal Server IP address is 192.168.1.2
    31-10-2009 11:37:10:Info   : Home SSID is ***********
    31-10-2009 11:37:10:Info   : Server port is 6000
    31-10-2009 11:37:10:Info   : Server pingable is True
    31-10-2009 11:37:10:Info   : Client will send GPS co-ords every 1Secs
    31-10-2009 11:37:10:Info   : Client will try to resend GPS co-ords every 600 Secs when no network connection
    31-10-2009 11:37:10:Info   : Client will send tracking data to your home server?: True
    31-10-2009 11:37:10:Info   : User ID is denblaa
    31-10-2009 11:37:10:Info   : Path to your pictures is:
    31-10-2009 11:37:10:Info   : Wake on Lan disabled
    31-10-2009 11:37:10:Info   : Speed multiplier set to 1,85
    31-10-2009 11:37:10:Info   : GPS com port set to COM8
    31-10-2009 11:37:10:Info   : GPS baud rate set to 4800
    31-10-2009 11:37:10:Info   : GPS data bits set to 8
    31-10-2009 11:37:10:Info   : GPS data bits set to 6
    31-10-2009 11:37:10:Info   : Client will send anonamous mapping data to MP3car.com.True
    31-10-2009 11:37:10:Info   : Client will delete at least 0  points.
    31-10-2009 11:37:10:Info   : Client will upload mapping data automatically to MP3Car.com.
    31-10-2009 11:37:10:Info   : Your secure user id is *****************
    31-10-2009 11:37:11:Info   : Client will send mapping data to MP3car.com via a proxy.False
    31-10-2009 11:37:11:Info   : Proxy IP address is 127.0.0.1
    31-10-2009 11:37:11:Info   : Proxy port number is 8080
    31-10-2009 11:37:11:Info   : Proxy log in name is User to log into proxy
    31-10-2009 11:37:11:Info   : Proxy password is Password to log into proxy
    31-10-2009 11:37:11:Debug  : Updating form text
    31-10-2009 11:37:11:Debug  : Starting search for network.
    31-10-2009 11:37:11:Debug  : Ending search for network.
    31-10-2009 11:37:11:Debug  : In isConnected
    31-10-2009 11:37:12:Debug  : Network and internet are available
    31-10-2009 11:37:12:Debug  : Checking SSID
    31-10-2009 11:37:12:Debug  : External network
    31-10-2009 11:37:12:Debug  : Updating form text
    31-10-2009 11:37:12:Debug  : Starting search for network.
    31-10-2009 11:37:12:Debug  : Ending search for network.
    31-10-2009 11:37:12:Debug  : Resend complete
    client's ini:
    [General]
    # What units to display the speed in. Values are MPH or KPH
    SpeedUnits=KPH
    #Do you want to collect tracking data.
    TrackData=True
    #Do you want to allow us to collect mapping data from you.
    MapData=True
    [Server]
    #The default user for GPSTracker server to show on start up.
    DefaultDisplayUser=
    # To test "wake on Lan" on your internal lan set this to your broadcast ip address i.e. 255.255.255.255
    # For "wake on Wan" set this to your external ip address supplied by your internet provider. Make sure this is fixed.
    EXTERNAL_IP_ADDRESS=***********
    #This is your servers ip address on your home network.
    INTERNAL_IP_ADDRESS=192.168.1.2
    HOME_SSID=*********
    Port=6000
    # This setting allows GPSTracker client to ping the server. This can speed up checking if the server is alive
    # but can open your server to outside attack so use with care.
    ServerPingable=True
    #Wake on Lan settings
    # Allows GPSTracker client to start up the server remotely. This assumes you have configuired wake on lan in your server pc's Bios.
    # If you have a router you probably need to port forward port 9 to your broadcast address.
    WOL=False
    # Mac address of your server pc. Type ipconfig /all in a dos box to find this.
    MacAddress=********
    # Is the server to send an sms in case of an alert.
    # Currently only Skype sms is supported. To enable set to value of Skype.
    SmsEnabled=False
    #Telephone numbers to be sent an sms. Comma seperate to use more than one.
    #Must start with country code. Either +44 or 0044 for example +448450928081
    SmsNumbers=+000000000
    #Debug output: can be set to 6 different values.
    #0 = off, 1=Fatal, 2=Error, 3=Warning, 4=Info, 5=Debug
    DebugLevel=
    [Client]
    UserId=denblaa
    TrackingPeriod=1
    retryPeriod=600
    AutoConnect=True
    DebugLevel=5
    #Full path to location of picture folder.
    PicPath=
    [GPS]
    Com=COM8
    Baud=4800
    DataBits=8
    Accurracy=6
    [Users]
    Users=
    [Mapping]
    #Mapping is MP3Car.com's attempt at creating a free open database of maps created by its user community.
    #All map data collection is done without collecting personnel data but the following helps hide you more.
    #Random deletion of points from startup or hibernate. This way when you start your journey from home or business nobody can track your starting location.
    #The tracker automatically collects positional data every 100m so base your minimum number around how many 100m's from home you want to obscure.
    #Remember the more data you delete the less map data we get.
    #Default is 10 (1km) which is mildly paranoid.
    MinPointsDeleted=0
    #How often do you want to upload the data collected to the MP3car.com website?
    #Options are:
    # 0 is manual.
    # 1 (default) is every day or next internet connection if more than one day has passed since last upload. Internet can be through wireless LAN.
    MapUpload=1
    [Proxy Settings]
    #Do want to use an ftp proxy server to send mapping data to MP3Car.com?
    useProxy=False
    #This is your ftp proxy server's ip address.
    ProxyIP=127.0.0.1
    #This is your ftp proxy server's port number (usually 21).
    ProxyPort=8080
    #This is your ftp proxy server's username for logging in.
    ProxyUserName=User to log into proxy
    #This is your ftp proxy server's password for logging in.
    ProxyPassword=Password to log into proxy
    is it me that are or what is wrong here?
  8. #148
    lambosprit's Avatar
    Sep 2006
    UK
    You haven't set your picpath. I think thats whats causing your client error. I'll probably have to check for that.
    I dont know why the screen is messed up. Its fine for me. what res are you at?
    also I'd remove your debug log post or delete parts of it because your giving away alot of info.
  9. #149
    Oct 2008
    Odense, Denmark
    debud edited...
    the server pc is running at 1024*768
    thought picture path was only needed on the client side and only if you wanted the picture stuff... i want that but have no cam attached yet so left it out
    EDIT: tried to edit the ini for the server side.... no ini ??
    EDIT: setting the path did the trick on the client side
  10. #150
    Oct 2008
    Odense, Denmark
    the client is now happy and it got a solid fix, checked the ini but the server is not getting any data... what could be wrong? the firewall is opened and i'm testing on local lan for the moment
    EDIT: it says 600000 next to the server ip... and it displays the external server ip... how do i know which ip it uses?
  1. it works.. auto syncing when you arrive home
    By collegeboyslive in forum General MP3Car Discussion
    Last Post: 11-29-2007, 06:36 PM
  2. Home
    By stasik-a4 in forum Map Monkey
    Last Post: 06-01-2007, 12:55 AM
  3. Image server
    By qwertylol in forum Software & Software Development
    Last Post: 01-10-2007, 03:02 AM
  4. MS Server 2003 help
    By nappyjim in forum Off Topic
    Last Post: 05-25-2006, 04:22 PM
  5. Replies: 2
    Last Post: 10-08-2005, 03:01 PM
