Page 16 of 32 FirstFirst ... 67891011121314151617181920212223242526 ... LastLast
Results 151 to 160 of 320
Thread: GPSTracker on home server
  1. #151
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by boelle View Post
    the client is now happy and it got a solid fix, checked the ini but the server is not getting any data... what could be wrong? the firewall is opened and i'm testing on local lan for the moment
    EDIT: it says 600000 next to the server ip... and it displays the external server ip... how do i know which ip it uses?
    you're correct , picture path is only used by the client. The server stores them in the database.
    The server ini is stored in C:\Documents and Settings\All Users\Application Data\GPSTracker. This is because it is not user specific.
    The 600000 is the number of minutes you've set in your client ini file for retry period. Its retry because for some reason the service hasn't been found. Check in the windows services (go to control panel>administrative tools>services) that the gpsservice is started.
    Also check that your GPSTracker.ini for the server has the internal ipaddress set to 127.0.0.1 and has the same port number as your client
  2. #152
    lambosprit's Avatar
    Sep 2006
    UK
    just had another brain wave. You said it was seeing external ip but you where on internal network. This means that your ssid setting has not been set right. The way the client decides what Ip address to use is by determining whether the network is a local or remote one. It does this by checking the ssid of the network and compares it to the setting in the client ini file. I think its even case sensitive.
    So check your ssid or set the external ip address to be the same as the internal while you test on the same machine.
  3. #153
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    the server and client pc are running on the internal network by cable but i have set up the same ip for internal and external at the client end and they do communicate... but when the server needs to redraw the map (almost instant) i get this error thing:
  4. #154
    lambosprit's Avatar
    Sep 2006
    UK
    any chance of a translation or at least the language its in?
  5. #155
    Oct 2008
    Odense, Denmark
    its in danish.. as you have figured there is a script error at line 143... but i cant figure out whats wrong... if i just start the client thing used to display where the car are but i do not do anything other there are no error.... the error comes as soon i select a car to track
  6. #156
    lambosprit's Avatar
    Sep 2006
    UK
    well according to the error message its when its loading the geofence data. Have you checked the debug log to see what it says?
    You could try renaming the tracking.db3 file so everything is created from scratch again just to see if it works. If it does you could send me the db3 file to have a look at for errors.
  7. #157
    Oct 2008
    Odense, Denmark
    you are right about geofence... just deletede the log and got this in the new one:
    Code:
    10-11-2009 16:12:45:Info   : GPSTracker server version :3.0.3562.41321
    10-11-2009 16:12:45:Info   : Default User ID to display is denblaa
    10-11-2009 16:12:45:Info   : Available users are denblaa
    10-11-2009 16:12:45:Info   : Speed units set to KPH
    10-11-2009 16:12:49:Warning: Exception caught while reading geofence data :System.Data.SQLite.SQLiteException: SQLite error
    no such column: user
       ved System.Data.SQLite.SQLite3.Prepare(SQLiteConnection cnn, String strSql, SQLiteStatement previous, UInt32 timeoutMS, String& strRemain)
       ved System.Data.SQLite.SQLiteCommand.BuildNextCommand()
       ved System.Data.SQLite.SQLiteCommand.GetStatement(Int32 index)
       ved System.Data.SQLite.SQLiteDataReader.NextResult()
       ved System.Data.SQLite.SQLiteDataReader..ctor(SQLiteCommand cmd, CommandBehavior behave)
       ved System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior)
       ved System.Data.SQLite.SQLiteCommand.ExecuteReader()
       ved VirtualEarth.DatabaseProcessor.loadGeoPoints(String id)
    10-11-2009 16:13:27:Info   : GPSTracker server version :3.0.3562.41321
    10-11-2009 16:13:27:Info   : Default User ID to display is denblaa
    10-11-2009 16:13:27:Info   : Available users are denblaa
    10-11-2009 16:13:27:Info   : Speed units set to KPH
  8. #158
    Oct 2008
    Odense, Denmark
    the log from the service:
    Code:
    10-11-2009 16:18:43:Info   : Service stopping
    10-11-2009 16:18:43:Error  : Unable to start listener. Check GPSTracker not already running in task manager and that the IP address is correct
    10-11-2009 16:18:43:Info   : Service stopped
    10-11-2009 16:18:43:Error  : Error message :System.Net.Sockets.SocketException: En blokeringshandling blev afbrudt af et kald til WSACancelBlockingCall
       ved System.Net.Sockets.Socket.Accept()
       ved System.Net.Sockets.TcpListener.AcceptTcpClient()
       ved GPSTracker.GPSTracker.ListenForConnections()
    10-11-2009 16:18:45:Info   : GPSTracker server version :3.0.3563.41970
    10-11-2009 16:18:45:Info   : Server IP address is 127.0.0.1
    10-11-2009 16:18:45:Info   : Server is pingable: False
    10-11-2009 16:18:45:Info   : Server port is 6000
    10-11-2009 16:18:45:Info   : Sms is enabled: False
    10-11-2009 16:18:45:Info   : Sms numbers are : +000000000
    10-11-2009 16:18:45:Info   : GPSTracker service started
  9. #159
    Oct 2008
    Odense, Denmark
    need a valid fix before i can try more.. i renamed the tracking db file but it cant create more than the initial file before there are a valid fix
  10. #160
    May 2007
    Just installed the client in the car when I got home and now I'm installing the server on my PC. I did not know the MAC address of the server while I was in the car so I left it blank- hopefully it will be OK; will test it out tomorrow
  1. it works.. auto syncing when you arrive home
    By collegeboyslive in forum General MP3Car Discussion
    Last Post: 11-29-2007, 06:36 PM
  2. Home
    By stasik-a4 in forum Map Monkey
    Last Post: 06-01-2007, 12:55 AM
  3. Image server
    By qwertylol in forum Software & Software Development
    Last Post: 01-10-2007, 03:02 AM
  4. MS Server 2003 help
    By nappyjim in forum Off Topic
    Last Post: 05-25-2006, 04:22 PM
  5. Replies: 2
    Last Post: 10-08-2005, 03:01 PM
