Page 18 of 32 FirstFirst ... 8910111213141516171819202122232425262728 ... LastLast
Results 171 to 180 of 318
Thread: GPSTracker on home server
  1. #171
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    :-D i dont even use proxy, just thought i have made a mistake without me notice
  2. #172
    Oct 2008
    Odense, Denmark
    i got the service running, but it still will not update... any advice on troubleshooting? did try to disable firewall
  3. #173
    Oct 2008
    Odense, Denmark
    also the client are not that willing to pop up when started... it just sits there in the task bar
    when trying to right click and choose close the app has stopped responding and i get the normal option to send an error report
  4. #174
    Oct 2008
    Odense, Denmark
    deleteing all logs and DB did help that... but no updates yet
    will try delete again on the server
  5. #175
    Oct 2008
    Odense, Denmark
    did delete the log and DB on server but no updates
  6. #176
  7. #177
    Oct 2008
    Odense, Denmark
    will try that on client now.. but server pc is taken by girlfriend playing world of warcraft for the next couple of hours
  8. #178
  9. #179
    Oct 2008
    Odense, Denmark
    did not help on the client side... hmm... just going to grap a fresh copy of my client ini..
    Code:
    [General]
    # What units to display the speed in. Values are MPH or KPH
    SpeedUnits=KPH
    #Do you want to collect tracking data.
    TrackData=True
    #Do you want to allow us to collect mapping data from you.
    MapData=True
    [Server]
    #The default user for GPSTracker server to show on start up.
    DefaultDisplayUser=
    # ********** To test "wake on Lan" on your internal lan set this to your broadcast ip address i.e. 255.255.255.255
    # For "wake on Wan" set this to your external ip address supplied by your internet provider. Make sure this is fixed.
    EXTERNAL_IP_ADDRESS=192.168.1.2
    #This is your servers ip address on your home network.
    INTERNAL_IP_ADDRESS=192.168.1.2
    HOME_SSID=*******
    Port=6000
    # This setting allows GPSTracker client to ping the server. This can speed up checking if the server is alive
    # but can open your server to outside attack so use with care.
    ServerPingable=True
    #Wake on Lan settings
    # Allows GPSTracker client to start up the server remotely. This assumes you have configuired wake on lan in your server pc's Bios.
    # If you have a router you probably need to port forward port 9 to your broadcast address.
    WOL=False
    # Mac address of your server pc. Type ipconfig /all in a dos box to find this.
    MacAddress=*********
    # Is the server to send an sms in case of an alert.
    # Currently only Skype sms is supported. To enable set to value of Skype.
    SmsEnabled=False
    #Telephone numbers to be sent an sms. Comma seperate to use more than one.
    #Must start with country code. Either +44 or 0044 for example +448450928081
    SmsNumbers=+000000000
    #Debug output: can be set to 6 different values.
    #0 = off, 1=Fatal, 2=Error, 3=Warning, 4=Info, 5=Debug
    DebugLevel=
    [Client]
    UserId=denblaa
    TrackingPeriod=1
    retryPeriod=600
    AutoConnect=True
    DebugLevel=4
    #Full path to location of picture folder.
    PicPath=c:\gpspic
    [GPS]
    Com=COM8
    Baud=4800
    DataBits=8
    Accurracy=6
    [Users]
    Users=
    [Mapping]
    #Mapping is MP3Car.com's attempt at creating a free open database of maps created by its user community.
    #All map data collection is done without collecting personnel data but the following helps hide you more.
    #Random deletion of points from startup or hibernate. This way when you start your journey from home or business nobody can track your starting location.
    #The tracker automatically collects positional data every 100m so base your minimum number around how many 100m's from home you want to obscure.
    #Remember the more data you delete the less map data we get.
    #Default is 10 (1km) which is mildly paranoid.
    MinPointsDeleted=0
    #How often do you want to upload the data collected to the MP3car.com website?
    #Options are:
    #        0 is manual.
    #        1 (default) is every day or next internet connection if more than one day has passed since last upload. Internet can be through wireless LAN.
    MapUpload=1
    [Proxy Settings]
    #Do want to use an ftp proxy server to send mapping data to MP3Car.com?
    useProxy=False
    #This is your ftp proxy server's ip address.
    ProxyIP=127.0.0.1
    #This is your ftp proxy server's port number (usually 21).
    ProxyPort=8080
    #This is your ftp proxy server's username for logging in.
    ProxyUserName=User to log into proxy
    #This is your ftp proxy server's password for logging in.
    ProxyPassword=Password to log into proxy
    i have set a name for wireless even that i do not use it.. the car pc and server is in the same network using wired connection
    the ini for the server will follow when the GF takes a break in the game
  10. #180
    Oct 2008
    Odense, Denmark
    Quote Originally Posted by Enforcer View Post
    VNC in and change it
    hmm.... a few things could happen... (we are living together) either i get some private parts crushed or cut off or in a sling.... so i will take a pass
  1. it works.. auto syncing when you arrive home
    By collegeboyslive in forum General MP3Car Discussion
    Last Post: 11-29-2007, 07:36 PM
  2. Home
    By stasik-a4 in forum Map Monkey
    Last Post: 06-01-2007, 01:55 AM
  3. Image server
    By qwertylol in forum Software & Software Development
    Last Post: 01-10-2007, 04:02 AM
  4. MS Server 2003 help
    By nappyjim in forum Off Topic
    Last Post: 05-25-2006, 05:22 PM
  5. Replies: 2
    Last Post: 10-08-2005, 04:01 PM
