Page 19 of 32 FirstFirst ... 91011121314151617181920212223242526272829 ... LastLast
Results 181 to 190 of 318
Thread: GPSTracker on home server
  1. #181
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    client debug:
    Code:
    1/11/2009 19:40:23:Info   : GPSTracker client version :3.0.3565.30116
    21/11/2009 19:40:23:Info   : External Server IP address is 192.168.1.2
    21/11/2009 19:40:23:Info   : Internal Server IP address is 192.168.1.2
    21/11/2009 19:40:23:Info   : Home SSID is ******
    21/11/2009 19:40:23:Info   : Server port is 6000
    21/11/2009 19:40:23:Info   : Server pingable is True
    21/11/2009 19:40:23:Info   : Client will send GPS co-ords every 1Secs
    21/11/2009 19:40:23:Info   : Client will try to resend GPS co-ords every 600 Secs when no network connection
    21/11/2009 19:40:23:Info   : Client will send tracking data to your home server?: True
    21/11/2009 19:40:23:Info   : User ID is denblaa
    21/11/2009 19:40:23:Info   : Path to your pictures is: c:\gpspic
    21/11/2009 19:40:23:Info   : Wake on Lan disabled
    21/11/2009 19:40:23:Info   : Speed multiplier set to 1.85
    21/11/2009 19:40:23:Info   : GPS com port set to COM8
    21/11/2009 19:40:23:Info   : GPS baud rate set to 4800
    21/11/2009 19:40:23:Info   : GPS data bits set to 8
    21/11/2009 19:40:23:Info   : GPS data bits set to 6
    21/11/2009 19:40:23:Info   : Client will send anonamous mapping data to MP3car.com.True
    21/11/2009 19:40:23:Info   : Client will delete at least 0  points.
    21/11/2009 19:40:23:Info   : Client will upload mapping data automatically to MP3Car.com.
    21/11/2009 19:40:23:Info   : Your secure user id is 6f0d7d01-89b0-4280-987d-beb3ed166778
    21/11/2009 19:40:24:Info   : Client will send mapping data to MP3car.com via a proxy.False
    21/11/2009 19:40:24:Info   : Proxy IP address is 127.0.0.1
    21/11/2009 19:40:24:Info   : Proxy port number is 8080
    21/11/2009 19:40:24:Info   : Proxy log in name is User to log into proxy
    21/11/2009 19:40:24:Info   : Proxy password is Password to log into proxy
  2. #182
    Oct 2008
    Odense, Denmark
    tried to disable firewall at server and telnet on port 6000... no luck :-(
  3. #183
    Oct 2008
    Odense, Denmark
    tried to make the internal ip of the server 192.168.1.2.. still no luck
  4. #184
    Oct 2008
    Odense, Denmark
    but now telnet from the client works..... could it be that the service at the server does not listen for data?
    EDIT: DOH since i can telnet and get a response there must be something that listens.... i guess the client does not send the data, that adds with the client is very slow at open so that i can see the window with the buttons and all... but i might be wrong
  5. #185
    Oct 2008
    Odense, Denmark
    congrats we have updates.... but now back to the error when loading geofence data... the line 143 thing
  6. #186
    Oct 2008
    Odense, Denmark
    any advice on hoe i could do some more troubleshooting?
    Blessed are the "cracked" for it is they who let in the light.
  7. #187
    lambosprit's Avatar
    Sep 2006
    UK
    Sorry for the long time away but I needed a break for a while. Supporting three apps gets busy at times.
    anyway back now so will try to answer your questions and give more help
  8. #188
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by boelle View Post
    also the client are not that willing to pop up when started... it just sits there in the task bar
    when trying to right click and choose close the app has stopped responding and i get the normal option to send an error report
    It can be a long time before it responds. It depends on how much data is trying to be sent to the server and how long it takes to time out (thats why deletig the database seemed to cure it). I thought about threading it but that causes other issues. If you just wait for a minute or 2 it does become responsive.
  9. #189
    lambosprit's Avatar
    Sep 2006
    UK
    did not help on the client side... hmm... just going to grap a fresh copy of my client ini..
    Code:
    [General]
    # What units to display the speed in. Values are MPH or KPH
    SpeedUnits=KPH
    #Do you want to collect tracking data.
    TrackData=True
    #Do you want to allow us to collect mapping data from you.
    MapData=True
    [Server]
    #The default user for GPSTracker server to show on start up.
    DefaultDisplayUser=
    # ********** To test "wake on Lan" on your internal lan set this to your broadcast ip address i.e. 255.255.255.255
    # For "wake on Wan" set this to your external ip address supplied by your internet provider. Make sure this is fixed.
    EXTERNAL_IP_ADDRESS=192.168.1.2
    #This is your servers ip address on your home network.
    INTERNAL_IP_ADDRESS=192.168.1.2
    HOME_SSID=*******
    Port=6000
    # This setting allows GPSTracker client to ping the server. This can speed up checking if the server is alive
    # but can open your server to outside attack so use with care.
    ServerPingable=True
    #Wake on Lan settings
    # Allows GPSTracker client to start up the server remotely. This assumes you have configuired wake on lan in your server pc's Bios.
    # If you have a router you probably need to port forward port 9 to your broadcast address.
    WOL=False
    # Mac address of your server pc. Type ipconfig /all in a dos box to find this.
    MacAddress=*********
    # Is the server to send an sms in case of an alert.
    # Currently only Skype sms is supported. To enable set to value of Skype.
    SmsEnabled=False
    #Telephone numbers to be sent an sms. Comma seperate to use more than one.
    #Must start with country code. Either +44 or 0044 for example +448450928081
    SmsNumbers=+000000000
    #Debug output: can be set to 6 different values.
    #0 = off, 1=Fatal, 2=Error, 3=Warning, 4=Info, 5=Debug
    DebugLevel=
    [Client]
    UserId=denblaa
    TrackingPeriod=1
    retryPeriod=600
    AutoConnect=True
    DebugLevel=4
    #Full path to location of picture folder.
    PicPath=c:\gpspic
    [GPS]
    Com=COM8
    Baud=4800
    DataBits=8
    Accurracy=6
    [Users]
    Users=
    [Mapping]
    #Mapping is MP3Car.com's attempt at creating a free open database of maps created by its user community.
    #All map data collection is done without collecting personnel data but the following helps hide you more.
    #Random deletion of points from startup or hibernate. This way when you start your journey from home or business nobody can track your starting location.
    #The tracker automatically collects positional data every 100m so base your minimum number around how many 100m's from home you want to obscure.
    #Remember the more data you delete the less map data we get.
    #Default is 10 (1km) which is mildly paranoid.
    MinPointsDeleted=0
    #How often do you want to upload the data collected to the MP3car.com website?
    #Options are:
    #        0 is manual.
    #        1 (default) is every day or next internet connection if more than one day has passed since last upload. Internet can be through wireless LAN.
    MapUpload=1
    [Proxy Settings]
    #Do want to use an ftp proxy server to send mapping data to MP3Car.com?
    useProxy=False
    #This is your ftp proxy server's ip address.
    ProxyIP=127.0.0.1
    #This is your ftp proxy server's port number (usually 21).
    ProxyPort=8080
    #This is your ftp proxy server's username for logging in.
    ProxyUserName=User to log into proxy
    #This is your ftp proxy server's password for logging in.
    ProxyPassword=Password to log into proxy
    i have set a name for wireless even that i do not use it.. the car pc and server is in the same network using wired connection
    the ini for the server will follow when the GF takes a break in the game
    You should really have your user list filled in, otherwise the server doesn't know what users it has to track and display.
    Your default user should also be set on the client. This should be diffeent for each client.
    Your debug level for the server isn't set. I think it defaults to 4 if nothings set but while your testing they should both be set to 5. When your happy you can bring the debug level down.
  10. #190
    lambosprit's Avatar
    Sep 2006
    UK
    I think I agree with enforcer that its a probably a nationalisation issue. Can you tell me what settings you have for that? I assume dutch. I will try to create a vm machine setup like you and see if I can recreate.
    Is there anything in the server log that suggests an error?
  1. it works.. auto syncing when you arrive home
    By collegeboyslive in forum General MP3Car Discussion
    Last Post: 11-29-2007, 07:36 PM
  2. Home
    By stasik-a4 in forum Map Monkey
    Last Post: 06-01-2007, 01:55 AM
  3. Image server
    By qwertylol in forum Software & Software Development
    Last Post: 01-10-2007, 04:02 AM
  4. MS Server 2003 help
    By nappyjim in forum Off Topic
    Last Post: 05-25-2006, 05:22 PM
  5. Replies: 2
    Last Post: 10-08-2005, 04:01 PM
