Page 23 of 32 FirstFirst ... 1314151617181920212223242526272829303132 LastLast
Results 221 to 230 of 320
Thread: GPSTracker on home server
  1. #221
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    debug while tryin to add geofence
    02-04-2010 11:15:27:Info : GPSTracker server version :3.1.3607.24505
    02-04-2010 11:15:27ebug : C:\Documents and Settings\All Users\Application Data\GPSTracker\gpstracker.ini
    02-04-2010 11:15:27:Info : Default User ID to display is denblaa
    02-04-2010 11:15:27:Info : Available users are denblaa
    02-04-2010 11:15:27:Info : Speed units set to KPH
    02-04-2010 11:15:27ebug : Server client will display last 1 days of tracks.
    02-04-2010 11:15:27ebug : Opening webpage
    02-04-2010 11:15:34:Info : No valid history available to load for denblaa
    02-04-2010 11:15:36ebug : Reloading Geofence
    02-04-2010 11:15:36:Warning: Error caught while checking for table geofence :System.Data.SQLite.SQLiteException: SQLite error
    no such table: geofence
    ved System.Data.SQLite.SQLite3.Prepare(SQLiteConnectio n cnn, String strSql, SQLiteStatement previous, UInt32 timeoutMS, String& strRemain)
    ved System.Data.SQLite.SQLiteCommand.BuildNextCommand( )
    ved System.Data.SQLite.SQLiteCommand.GetStatement(Int3 2 index)
    ved System.Data.SQLite.SQLiteDataReader.NextResult()
    ved System.Data.SQLite.SQLiteDataReader..ctor(SQLiteCo mmand cmd, CommandBehavior behave)
    ved System.Data.SQLite.SQLiteCommand.ExecuteReader(Com mandBehavior behavior)
    ved System.Data.SQLite.SQLiteCommand.ExecuteReader()
    ved VirtualEarth.DatabaseProcessor.checkTable(String tablename)
    02-04-2010 11:15:36ebug : geofence found with fewer than 3 points
    02-04-2010 11:16:06ebug : Currently tracking denblaa
    02-04-2010 11:16:06:Info : No valid history available to load for denblaa
    02-04-2010 11:16:08ebug : Reloading Geofence
    02-04-2010 11:16:08ebug : geofence found with fewer than 3 points
    02-04-2010 11:16:27:Warning: Error caught while checking for table alert :System.Data.SQLite.SQLiteException: SQLite error
    no such table: alert
    02-04-2010 11:17:15ebug : Currently tracking denblaa
    02-04-2010 11:17:53:Info : GPSTracker server version :3.1.3607.24505
    02-04-2010 11:17:53ebug : C:\Documents and Settings\All Users\Application Data\GPSTracker\gpstracker.ini
    02-04-2010 11:17:53:Info : Default User ID to display is denblaa
    02-04-2010 11:17:53:Info : Available users are denblaa
    02-04-2010 11:17:53:Info : Speed units set to KPH
    02-04-2010 11:17:53ebug : Server client will display last 1 days of tracks.
    02-04-2010 11:17:53ebug : Opening webpage
    02-04-2010 11:18:03ebug : Reloading Geofence
    02-04-2010 11:18:03ebug : geofence found with fewer than 3 points
    02-04-2010 11:21:53:Info : GPSTracker server version :3.1.3607.24505
    02-04-2010 11:21:53ebug : C:\Documents and Settings\All Users\Application Data\GPSTracker\gpstracker.ini
    02-04-2010 11:21:53:Info : Default User ID to display is denblaa
    02-04-2010 11:21:53:Info : Available users are denblaa
    02-04-2010 11:21:53:Info : Speed units set to KPH
    02-04-2010 11:21:53ebug : Server client will display last 1 days of tracks.
    02-04-2010 11:21:53ebug : Opening webpage
    02-04-2010 11:21:58ebug : Geofence being added
    02-04-2010 11:22:01ebug : Reloading Geofence
    02-04-2010 11:22:01ebug : geofence found with fewer than 3 points
    02-04-2010 11:22:03ebug : Geofence being added
    02-04-2010 11:22:14ebug : Geofence being added
    02-04-2010 11:22:19ebug : Geofence being finshed
    02-04-2010 11:22:22ebug : Geofence being deleted
    02-04-2010 11:22:23ebug : Geofence being deleted
    02-04-2010 11:22:25ebug : Currently tracking denblaa
    02-04-2010 11:22:28ebug : Reloading Geofence
    02-04-2010 11:22:28ebug : geofence found with fewer than 3 points
    Blessed are the "cracked" for it is they who let in the light.
  2. #222
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by boelle View Post
    Ok that helps. The error message is ok , it creates the table afterwards. Looking at your log at the end you seem to add a geofence but then delete it straight away. Can you post how you add a geofence. You should click the add geofence button (top one of the three). Then click on the map to show the point co-ords of your geofence shape. When finished click the middle button Finish geofence. You should then see the geofence appear on your map.
  3. #223
    Oct 2008
    Odense, Denmark
    no problem.. take your time
    seems that you have been pretty busy lately with the phone app
  4. #224
  5. #225
    Oct 2008
    Odense, Denmark
    only problem is that the map starts centered at your location in the UK (i guees here) and i get the error even if i try to click on the map to either move it or add a geofence... not sure what goes on here
  6. #226
    Oct 2008
    Odense, Denmark
    i add geofence like you instructed... the delete was just to test
    either way as soon i clik on add or the map i get the error
  7. #227
    Oct 2008
    Odense, Denmark
    now the server starts like this... give me a gun with one bullet before i go insane :-D
  8. #228
    lambosprit's Avatar
    Sep 2006
    UK
    ok. So have you followed my instructions and still get the error or does it happen before then, during etc. Does it happen after you click the add geofence and then click on the map? Need as much detail as possible as its working fine for me
  9. #229
    Oct 2008
    Odense, Denmark
    if i start from scratch (deleting logs and sql files) it does happen as soon the server got data from the client and i press a car to track (only one now)
    it does also happen as soon i click the map either to move it or to mark a geofence point... it does also happen if i click start geofence or finish or delete
  10. #230
    lambosprit's Avatar
    Sep 2006
    UK
    try using this new html file. Just copy it over you're current one. It chould output more messages so send me the results
    Attached Files Attached Files
  1. it works.. auto syncing when you arrive home
    By collegeboyslive in forum General MP3Car Discussion
    Last Post: 11-29-2007, 06:36 PM
  2. Home
    By stasik-a4 in forum Map Monkey
    Last Post: 06-01-2007, 12:55 AM
  3. Image server
    By qwertylol in forum Software & Software Development
    Last Post: 01-10-2007, 03:02 AM
  4. MS Server 2003 help
    By nappyjim in forum Off Topic
    Last Post: 05-25-2006, 04:22 PM
  5. Replies: 2
    Last Post: 10-08-2005, 03:01 PM
