Page 25 of 32 FirstFirst ... 151617181920212223242526272829303132 LastLast
Results 241 to 250 of 320
Thread: GPSTracker on home server
  1. #241
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    Quote Originally Posted by lambosprit View Post
    What do you have set for that kind of thing?
    no settings.... its just plugged to usb and transmit data
    Blessed are the "cracked" for it is they who let in the light.
  2. #242
    Oct 2008
    Odense, Denmark
    i might be wayyy wrong here.... but to me it seems like the comma (,) should be after digit 2 and be made a dot (.) instead... just a thought
  3. #243
    Oct 2008
    Odense, Denmark
    my gps test app says:
    lat: N 55'19.6331'
    lon: E 010'26.2840'
    only the last 2 digits are flipping back and forth (unstable)
  4. #244
    Oct 2008
    Odense, Denmark
    more data...
    HDop: 5,3
    pdop: 5,4
    direction is spinning like hell but guess it's only stable when moving...
  5. #245
    lambosprit's Avatar
    Sep 2006
    UK
    try this little test app. You need to cut and paste $GPGGA,140853.000,5519.5996,N,01026.3531,E,1,03,50 .0,28.7,M,44.1,M,,0000*57
    to the text box. It then should give you 55.32666 and 10.43921 anthing ele and we have atest app to solve the problem
    Attached Files Attached Files
  6. #246
    Oct 2008
    Odense, Denmark
    got one box saying: 551960,6 and another saying 102635,516666667
  7. #247
    lambosprit's Avatar
    Sep 2006
    UK
    ok that was what I was expecting but not good.
  8. #248
  9. #249
    lambosprit's Avatar
    Sep 2006
    UK
    try this. First number should be right, Second not.
    edit. Attached fixed installer for testig if the test app works. You will need to stop the service manually first before install.
  10. #250
    Oct 2008
    Odense, Denmark
    first number is now 5519,5996 next number is 55,32666 and now a third number 102635,516666667
  1. it works.. auto syncing when you arrive home
    By collegeboyslive in forum General MP3Car Discussion
    Last Post: 11-29-2007, 07:36 PM
  2. Home
    By stasik-a4 in forum Map Monkey
    Last Post: 06-01-2007, 01:55 AM
  3. Image server
    By qwertylol in forum Software & Software Development
    Last Post: 01-10-2007, 04:02 AM
  4. MS Server 2003 help
    By nappyjim in forum Off Topic
    Last Post: 05-25-2006, 05:22 PM
  5. Replies: 2
    Last Post: 10-08-2005, 04:01 PM
