Page 26 of 32 FirstFirst ... 1617181920212223242526272829303132 LastLast
Results 251 to 260 of 320
Thread: GPSTracker on home server
  1. #251
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by boelle View Post
    first number is now 5519,5996 next number is 55,32666 and now a third number 102635,516666667
    , or . ?
  2. #252
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Definitely looks like an issue with the , being used as a decimal point . in Europe.
    Had the same issue when I was doing the french petrol prices and GPS reading.
  3. #253
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    , i all 3 cases
    Blessed are the "cracked" for it is they who let in the light.
  4. #254
    Oct 2008
    Odense, Denmark
    funny thing is that the client in the car shows speeds from 1 all the way up to 30
    and the server goes past the speed of sound.... damm peugeot has made a fine car when they made the 106
    and now even that it's set to kph it has now changed to mph.... now where is that rope that fits snugly arround my neck *lol*
    but both my test app and garmin have not trouble with the gps signal
  5. #255
    lambosprit's Avatar
    Sep 2006
    UK
    Don't worry, its a problem with my app but now I know what it is I can fix it.
    Its actually two problems. The first was when converting a string (the gps message) into a number it was getting confused. Thats now fixed.
    The problem left is when I convert back to a string to send to the web page it changes the decimal to a comma. Still should have it solved soon.
  6. #256
    Oct 2008
    Odense, Denmark
    thanks a lot
    just remember to "cover your ***" regarding national issues etc... a quick thought could be that the app looks at what country the os it set to and convert the prober way... hope you gat the point in what i just wrote
  7. #257
    lambosprit's Avatar
    Sep 2006
    UK
    Here's a version to test.
    Lots of warnings though.
    It took a lot to make the app culture independant so its had lots of changes i.e. there maybe lots of new bugs. I don't hav my gps with me to test it as I'm travelling at moment. All the apps have changed.
    I had to change the databae definitions so you will have to delete all you're tracking.db3's. The app will recreate them all.
    The installer has been changed to force a uninstall if you are installing the service. Typically people install both client and service on the same machine for testing so even if the service doesn't exist it will still try to uninstall. The uninstal will ask which module you want to uninstal. Just select service not client. During this uninstall you will be asked if you wish to save the ini file. This is only done for the service not for the client.
    I will be away from the internet from end of today for two weeks so can help only today.
  8. #258
    Oct 2008
    Odense, Denmark
    got this error when running server:
    Se slutningen af denne meddelelse, hvis du vil have detaljer om,
    hvordan du starter JIT-fejlfinding i stedet for denne dialogboks.
    ************** Undtagelsestekst **************
    System.IO.FileLoadException: Filen eller assemblyen 'System.Data.SQLite, Version=1.0.62.0, Culture=neutral, PublicKeyToken=db937bc2d44ff139' eller en af dens afhængigheder kunne ikke indlæses. Den fundne assemblys manifestdefinition svarer ikke til assemblyens reference. (Undtagelse fra HRESULT: 0x80131040)
    Filnavn: 'System.Data.SQLite, Version=1.0.62.0, Culture=neutral, PublicKeyToken=db937bc2d44ff139'
    ved VirtualEarth.DatabaseProcessor.readIdData(String id)
    ved VirtualEarth.GPSServer.changeId()
    ved VirtualEarth.GPSServer.usersList_SelectedIndexChan ged(Object sender, EventArgs e)
    ved System.Windows.Forms.ListBox.OnSelectedIndexChange d(EventArgs e)
    ved System.Windows.Forms.ListBox.WmReflectCommand(Mess age& m)
    ved System.Windows.Forms.ListBox.WndProc(Message& m)
    ved System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
    ved System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
    ved System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    WRN: Logføring af assemblybinding er deaktiveret.
    Logføring af assemblybindingsfejl aktiveres ved at angive registreringsdatabaseværdien [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) til 1.
    Bemærk! Ydeevnen forringes ved logføring af assemblybindingsfejl.
    Denne funktion deaktiveres ved at fjerne registreringsdatabaseværdien [HKLM\Software\Microsoft\Fusion!EnableLog].
    ************** Indlæste assemblies **************
    mscorlib
    Assemblyversion: 2.0.0.0
    Win32-version: 2.0.50727.3607 (GDR.050727-3600)
    CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
    GPSTrackerServiceClient
    Assemblyversion: 3.1.3744.37683
    Win32-version: 3.1
    CodeBase: file:///C:/Programmer/GPSTracker/GPSTrackerServiceClient.exe
    Microsoft.VisualBasic
    Assemblyversion: 8.0.0.0
    Win32-version: 8.0.50727.3053 (netfxsp.050727-3000)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
    Win32-version: 2.0.50727.3053 (netfxsp.050727-3000)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Runtime.Remoting
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    mscorlib.resources
    System.Windows.Forms.resources
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_da_b77a5c561934e089/System.Windows.Forms.resources.dll
    ************** JIT-fejlfinding **************
    Hvis du vil aktivere JIT-fejlfinding, skal værdien jitDebugging indstilles
    i afsnittet system.windows.forms i konfigurationsfilen
    for programmet eller computeren.
    Programmet skal desuden kompileres med fejlfinding
    aktiveret.
    Eksempel:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    Når JIT-fejlfinding er aktiveret, bliver alle ikke-afviklede
    undtagelser sendt til den JIT-fejlfindingsfunktion, der er registreret på computeren, i stedet for
    at blive afviklet af denne dialogboks.
    also when installing server it fails at GPSTrackerService.exe
    i stopped the service but so far i have not tricked it to a successfull install
  9. #259
    Oct 2008
    Odense, Denmark
    this error also happens at the client now.... seems like it happens each time it writes to the sql
  10. #260
    lambosprit's Avatar
    Sep 2006
    UK
    did you delete the both tracking databases?
  1. it works.. auto syncing when you arrive home
    By collegeboyslive in forum General MP3Car Discussion
    Last Post: 11-29-2007, 07:36 PM
  2. Home
    By stasik-a4 in forum Map Monkey
    Last Post: 06-01-2007, 01:55 AM
  3. Image server
    By qwertylol in forum Software & Software Development
    Last Post: 01-10-2007, 04:02 AM
  4. MS Server 2003 help
    By nappyjim in forum Off Topic
    Last Post: 05-25-2006, 05:22 PM
  5. Replies: 2
    Last Post: 10-08-2005, 04:01 PM
