Page 29 of 32 FirstFirst ... 1920212223242526272829303132 LastLast
Results 281 to 290 of 320
Thread: GPSTracker on home server
  1. #281
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    no problem.... just take your time
    i have now gotten longer than before and i know that the "in the water problem" is due to missing digits and that calms me way down
    you can wait to after hols to fix the rest
    Blessed are the "cracked" for it is they who let in the light.
  2. #282
    lambosprit's Avatar
    Sep 2006
    UK
    Well I think you're lucky. I was going to give up on this because it was a bug in sqlite but while trapped here in South Africa because of the vulcano I couldn't do anything so just checked the site and its been fixed.
    Again no promises but I'm pretty hopeful it will work now.
    I'll have a look at ading you're translations as well
    Attached Files Attached Files
  3. #283
  4. #284
    Oct 2008
    Odense, Denmark
    UPPPS... have been so busy that i did not see your reply.. and for some strange reason i did not get a mail as i used to
    testing tomorrow
  5. #285
    Oct 2008
    Odense, Denmark
    got around to test...
    everything works
    have not tested the pics upload function, put i guess i can just drop some pics in the folder set in the ini... but what is the max format etc on pics?
    next thing would be how to tell the client in the car whatever we have an alarm or not... is that implemented yet?
  6. #286
    Oct 2008
    Odense, Denmark
    even that i'm indoor the speed jumps up and down... what can i do to get that stable?
    also in a other plugin (RRVM) it counts driven distance if i leave the pc on over night, still in doors... but i guess thats all related to the stream from the gps mouse
  7. #287
    Oct 2008
    Odense, Denmark
    another feature on the server could be that it zooms in on the selected car automatic at a selectable zoom level
    maybe an option to print out some kind of form on alarms (you select the start and stop time) and a map with the route the thives have driven and the indvidual logged points under that maybe along with the pics
  8. #288
    lambosprit's Avatar
    Sep 2006
    UK
    Quote Originally Posted by boelle View Post
    everything works
    Great new. Got the bugger nailed at last. For the pics just put them in the folder as you say. It sends the first one it finds and I think removes it once its sent (not sure about the last bt but thats what it should do). There isn't a format limit but obviously the bigger the file the slower the upload and so keep it small.
    Car alarm is implemented but its not easy to set up. The problem is setting skype up so it runs as a service. Its possible just hard. Its a problem of having the tracking server as a service which solves the problem of not being logged in (e.g because your pc rebooted) but skype usually needs a windows user to be logged in. What I'm thinking is to have two versions of the tracker server, effectively the old server version and the new service version. That way if your always logged in you can have the far simpler skype install.
  9. #289
    lambosprit's Avatar
    Sep 2006
    UK
    its a prblem with the accuracy of the gps. Other plugins like Festy's milage plugin has the same issue but has a setting to ignore speeds below a certain level. I could easily add that.
  10. #290
    lambosprit's Avatar
    Sep 2006
    UK
    If an alarm occures the sever automatically switches to that car and zooms into its location. It also automatically gets the client to track every 2 second rather than your ini settings. the zoom level isn't customisable at present.
    Hadn't thought of a print out but its all in the database so would be easy to do. Even the pictures are easy to get at. My idea was that you'd be telling the police where it was immediately rather than after the fact though.
    Glad to here its all working though and keep the suggestions comming in. If you fancy setting up the skype server I'll post a link to how to do it.
  1. it works.. auto syncing when you arrive home
    By collegeboyslive in forum General MP3Car Discussion
    Last Post: 11-29-2007, 06:36 PM
  2. Home
    By stasik-a4 in forum Map Monkey
    Last Post: 06-01-2007, 12:55 AM
  3. Image server
    By qwertylol in forum Software & Software Development
    Last Post: 01-10-2007, 03:02 AM
  4. MS Server 2003 help
    By nappyjim in forum Off Topic
    Last Post: 05-25-2006, 04:22 PM
  5. Replies: 2
    Last Post: 10-08-2005, 03:01 PM
