Results 1 to 8 of 8
Thread: Device recognised as GPS: yes, no, yes ,no?
    Low Bitrate mrborrie's Avatar
    Jan 2006
    Netherlands
    Device recognised as GPS: yes, no, yes ,no? thats what Simple GPS tester gives me... is my device broken? does seem to have a vieuw on 10 satalites but 0 fixes
    Volvo 760 Turbo Intecooler
    M900 + 512MB, 120GB HD, VroomPC casing, Wired GPS unit, Flipscreen 7"
    Vendor - Qube colin's Avatar
    Dec 2006
    Mine does that too.
    Jan 2006
    Netherlands
    Quote Originally Posted by colin View Post
    Mine does that too.
    so... whats up with that, you ever get a fix? mine worked great but now im reinstalling it in my home but the gps mouse is almost outside , unlike in my car its kinda far from the window but gets a good fix
    Dec 2006
    I found that in GPS programs it didn't matter. I also noticed that the NO case only occurred when certain NMEA strings were being sent from the GPS unit. In my head, I figured it was just a program error: the software only things the device is a GPS if it receives a certain NMEA string, if it receives other ones, it things it is a generic serial device and therefore doesn't fix.
    I think its a protocol thing, but iGuidance still sees everything fine, and by reading the NMEA strings manually, I know that it's all working.
    Jan 2006
    Netherlands
    well Sygic hates it!
    May 2008
    You could try using XPort and turning on the NMEA filter.
    Jan 2006
    Netherlands
    Quote Originally Posted by Sicarius View Post
    well i mounted it to somthing metal (it has a magnet) and it start working, also the weather cleared up.. so it works again... wierd.. thanks
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Pull out of the garage.
    You were getting 10 sats, but the signal was too weak to hit the fix threshold for each one. As long as you see changing data from at least 1 sat, it's basically functioning.
  1. Anyone's Infill G4 GPS not resuming from hibernation? Pls help!
    By Carz in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 03-31-2009, 05:22 PM
  2. Canīt get DirectX to work
    By Linde in forum Software & Software Development
    Last Post: 10-19-2007, 07:35 AM
  3. OEM GPS mod. Writeup + Pics
    By IntellaWorks in forum Hardware Development
    Last Post: 07-04-2006, 02:59 AM
  4. GlobalSat BT-338 Review
    By tom2112 in forum The Review Palace
    Last Post: 06-27-2005, 11:02 AM
  5. GPS device Locks
    By ryguy in forum CF Bug Reports
    Last Post: 06-19-2005, 06:09 PM
