Results 1 to 2 of 2
Thread: Centrafuse won't recognise my USB SiRF III GPS Receiver
    Jul 2009
    Toowoomba, Australia
    Hi, I am having a problem with Centrafuse 2.0, when I open navigation, it won't display any satellites of get a postition fix. I am using a USB SiRF III GPS Receiver from MoCoSo.
    Here is what I have done so far:
    - Installed the USB-Serial Driver
    - Installed the GPSInfo program
    - Run GPSInfo program- finds GPS reciever on Com Port 10 and baud 4800
    - picks up satellites and fixes position instantly
    Run Centrafuse - set Com Port to 10 and baud to 4800
    - load Australian Map
    and no signal.
    The instructions for the GPS Reciever say to set baud to 57600 but when I do this, the GPSInfo program won't find the reciever at all. I tried all the above with the GPSInfo program opened and closed, with GPS running and not.
    Has anyone had a similar problem? Thanks for your help, this forum is fantastic!
    Feb 2006
    Melbourne, Australia
    Set the Comport in Device Manager to 9 or lower, and select same port in CF.
    I have had a few instances of this, and are opting to use COM8 -works very well.
    Your default baud is most likely 4800, protocol = NMEA
    F6 Tornado Project Log ; HP Blackbird Watercooled Server
    Beta Tester for Centrafuse and 3dConnexion (No business affiliation with either)
  1. Replies: 5
    Last Post: 10-05-2006, 05:45 PM
  2. Earthmate GPS Receiver USB
    By sesshoumaru562 in forum Classified Archive
    Last Post: 08-25-2004, 12:36 PM
  3. simple soft to test USB GPS receiver
    By felix99 in forum GPS
    Last Post: 10-08-2002, 03:23 PM
  4. Got my Navman RandMcnally USB GPS NMEA 2.0 compliant receiver.
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 03-13-2002, 03:54 PM
