Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: 5hz GPS antenna w/USB?
  1. #21
    Variable Bitrate FPeter's Avatar
    May 2008
    Hungary
    after the "pre-alpha-beta" version, here is the v1.0
    and its running fine in 10Hz mode - under heavy testing...
    "case": Skoda Superb Elegance 1.8T
    Asrock G41MH-GE, E2180 2GHz dualcore, 1024MB DDR2/800, Samsung F1 750GB/7200RPM/32MB, M4-ATX, Lilliput FA1011 HDMI touchscreen, ASUS Xonar DG PCI, homemade Quectel L10 USB GPS
  2. #22
    Feb 2007
    Taylorsville, UT
    Quote Originally Posted by FPeter View Post
    How much are you selling that for??
    MTK chipset is way better than Sirf3 ! Glad people are finally starting to use it. I have an older MTK1 chip based GPS but it only does 9600baud on the serial port so I cant make it really work at much better than 1hz. (although it does respond to commands to change the output, including the update speed, there just isnt enough bandwidth on the serial link to crank it up)
    -James
    Car: 2004 GTI VR6 24v Turbo 2.8L, GT35R, 630cc, Unitronic, Bosch 044, etc, etc..
    Main PC:i7 920@4Ghz, 6GB DDR3, MSI X-58 Pro-E, Win 7 x64 RTM, Scythe Mugen2, 128GB G.Skill Falcon, 2x ATI4850 512MB Crossfire, Auzentech X-Fi Forte, Grado Labs SR-80
  3. #23
    Dec 2008
    Quote Originally Posted by Extide View Post
    edit-
    apparently the bt-q890 is basically whats shown above. from what i can tell, MTKII just means it can do AGPS data downloads, so you can get cold start fixes in less then 15sec (so long as you download the new coordinate data every 7 days).
    so what i have should work at 5hz, i must have had port settings wrong or something. the chip inside my reciever is the same (MTK3329), so ill play around a little more to see if i cant get 5hz working. it does claim in its specs sheet that its maximum port baud is 115200 and bluetooth will not support 5hz mode.
    if you look on qstarz website, they have a bunch of nice units. this one seems like the best carpc device- http://www.qstarz.com/Products/GPS%2...T-Q1000X-F.htm
  1. External antenna on a GPS reciever?
    By stonestatue in forum Wireless Communications
    Last Post: 01-07-2008, 01:32 AM
  2. OEM GPS Antenna
    By unixxx in forum GPS
    Last Post: 06-05-2006, 11:54 AM
  3. No GPS Signal from antenna on E46
    By dreamstriker in forum GPS
    Last Post: 09-16-2005, 10:45 AM
  4. Replies: 11
    Last Post: 12-06-2004, 04:48 PM
  5. Gps Module + External Antenna + Waas + Usb
    By e_z_street in forum GPS
    Last Post: 10-06-2004, 04:57 PM
