Results 1 to 9 of 9
Thread: GPS logging software preferably free
    Mar 2005
    Hey guys I was wondering what software you would recommend for use logging vehicle position vs. time to a CSV file. I would need the software to start when computer starts write a file then close it when the computer shuts down. The name of file could be based on GPS data so it could not overlap (I.E. time and day of trip start). I have a 5Hz GPS which I do not know if will work with many of the programs.
    I have searched and found goops, and something in french I don't know what is
    http://benichougps.blogspot.com/. There were also some other things mentioned like GPS logger, and GPSSecure, but they go way beyond what I want. Xport3 supposedly can log data (but I don't know how well it works). I have had bad experience with Xport in the past myself.
    Goops is full of fancy prettiness which I don't want. I just want it to record the lat and long with time 5 times a second. Then I can plug it into a USGS database later to get altitude.
    If I must I might be able to code something like this, but I don't really know anything about coding I just bang my head against problems till they work out usually.
    Thanks for any suggestions.
    SuperMod - OBDII GPS Logger forum
    Mar 2009
    Los Angeles
    Are you using windows, or is Linux or OSX acceptable?
    If you can use Linux or OSX, I find obdgpslogger to be pretty good :-)
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
    Mar 2005
    I am using windows unfortunately. It is a slimmed down XP nlite installation I made. I would prefer to keep using it, but if it is absolutely necessary I could swap. Thanks for the suggestion though.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Check out lambosprit's gps server app. It logs your position and allows you to load it to your own server.
    Want to:
    Mar 2005
    BTW Bugbyte I did get your message, but I won't get a chance to check into that for a bit. I will let you and others know how/if it works. Thanks for the suggestion.
    Maximum Bitrate DeltaFX's Avatar
    France
    Now Galileo is real. Muhahahahaha :p
    Maximum Bitrate hexxamillion's Avatar
    Dec 2007
    AZ
    Here are some also..though mainly LINUX/UNIX a few are cross platform: http://tuxmobil.org/linux_gps_naviga...lications.html
    "Live Free!!!...It's all about Open Source"
    Worklog:'09 Altima Android Tablet PC Dash Mount
    Old project'05 Nissan Altima Project (Intel D945GCLF2D)
    Vimeo Vids:Project Videos
    Homepage: HexxWorld.net
    Twitter:http://twitter.com/hexxamillion
    Mar 2005
    Quote Originally Posted by DeltaFX View Post
    I used that software to test my receiver and it worked perfectly to log data even at a 5Hz rate, but I do not believe I can have it automatically start, acquire satellites, name a file based on the date/time and start logging, then stop logging when windows begins to shut down. It was nice to get a super smooth 5Hz GPS track though and look at how well the corners and circles (I drove in a round about to test ) looked.
    Oct 2009
    Hi
    You might want to look at http://www.bt747.org that is related to SW that can do a lot of stuff and probably also what you are looking for.
    In my opinion is is best to use a dedicated logger (see http://www.bt747.org/compatible_gps).
  1. Replies: 65
    Last Post: 10-13-2009, 07:51 PM
  2. gps logging program
    By soundman98 in forum Crowdsourced Data Collection, Open Source Mapping And Routing
    Last Post: 08-19-2009, 05:40 AM
  3. South Africa ? Any free GPS software
    By peter6960 in forum GPS
    Last Post: 12-28-2005, 11:01 AM
