Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: QSTARZ BT-Q818X BT GPS Receiver
    Mar 2006
    Montreal
    Qstarz BT-Q818X Bluetooth GPS Receiver (66 ch MTKII, 42hrs, 5Hz Hardware Switch, Dual Interface USB/Bluetooth)
    66-Channel Performance tracking for fast acquisition and reacquisition Super high sensitivity -165dMb MTK II chipset Lower power consumption sup to 42hrs navigation time Less than 15 sec AGPS fix support Dual USB / Bluetooth 5Hz update rate, 3 level switch (5Hz-Nav-Off) for easy operation QZSS, DGPS(WAAS+EGNOS+MSAS) Support Auto On/Off function
    I decided to order this unit and havn't seen anything mentioned on MP3Car about it, but the price looks good and about the same as I paid for BU-353 4 years ago (that died last week)
    On this unit the 5Hz has a hardware switch, where-as on some MTK receivers you have to set it in software, which resets back to 1Hz when battery is drained, guess I'll have a new toy to play with next week.
    Spec:
    1. Chipset : MTK 2 GPS
    Module
    2. Channel : 66 Channel
    parallel satellite tracking
    3. Time to First Fix (TTFF) :
    < Average 1/33/35 sec.
    (Hot/Warm/Cold start);
    AGPS <15 sec
    4. Antenna : Built-in patch
    antenna with LNA
    5. Output Message :
    NMEA-0183 (V3.01) - GGA,
    GSA,GSV, RMC(default)
    6. Accuracy : < 3m CEP
    (Stand-Alone, S/A off); <
    2.5m CEP (DGPS)
    7. Sensitivity: -165dBm
    tracking
    8. Battery Life : Operating
    time 42 hours
    9. Dimension : 72.2 (L) X
    46.5 (W) X 20 (H) mm
    GPS ChipSet Comparison Table
    ChipSet Name
    MTK II
    MTK
    65 nm SiRF III
    90 nm SiRF III
    Number of Channels
    66
    51 or 32
    20
    20
    Sensitivity Rating
    (Negative lower is better)
    -165dBm
    -158dBm
    -159dBm
    -159dBm
    Power consumption
    (lower is better)
    very low
    low
    very low
    high
    TTFF (Time_To_First_Fix)
    very fast
    fast
    fast
    slow
    Editor's Choice
    Mar 2006
    Montreal
    ok received the 818x gps, it's hella fast scrolling the 5 hz lol i see in demo program, ill install it later tonight to try it out, see if iguidance 3.0 chokes or not :P
    Mar 2006
    Montreal
    good news about it, you dont have to use bluetooth, you can use USB as well, some other 5Hz receivers have usb just for charging only, no data! no more turning the unit on with a button unlike other 5Hz receivers either, it will run till battery is dead, and the pc bootup usb will turn it back on while charging...
    it has AGPS which takes about 10 seconds to update via their software, and the almanac data lasts up to 7 days! it sees alot of sats from inside center of home too...
    good thing is no waiting for BT to sync to start using gps if we use usb
    sees 9 sats in middle of home...
    Dec 2009
    canmore GT-750 FL
    Canmore GT-750 FL is another good Bluetooth GPS Receiver
    Similar to bt-q818x but more friendly use.
    Dec 2009
    Qstarz BT-Q818X bedox
    This GPS receiver has wonderful sensitivity, tracking, battery life, sync times... Equivalent if not better to a SirfIII chipset, and in a very small and reliable package. Best buy
    I purchased the Qstarz BT-Q818x from Bedox Inc. http://www.bedoxinc.com/qsbtblgpsre6.html
    for $63USD w/ free shi
    pping. This price included a small carring case for your GPS receiver.
    Feb 2006
    Melbourne, Australia
    @ Jasbulk: Stop spamming, Mate, you're doing the same on another carputer forum.
    F6 Tornado Project Log ; HP Blackbird Watercooled Server
    Beta Tester for Centrafuse and 3dConnexion (No business affiliation with either)
    Mar 2006
    Montreal
    carry case... lol, least no brokerage fees and canadian currentcy is about same, and besides i keep mine mounted on ceiling above window no wires seen so who cares
    FLAC Marvin Hlavac's Avatar
    May 2005
    Quote Originally Posted by tracker64 View Post
    I got my BT-Q818X several weeks ago, too, and I love it. Things do change in the industry, but as of today (December 2009), if I had to buy another GPS for a PC, I would not hesitate to buy it again. It meets my needs. I love the long battery life. I love the fact that you can use it via USB or via Bluetooth.
    Quote Originally Posted by mrbean_phillip View Post
    You've that right. Here's my reply to him . And I've read other of his postings elsewhere, too.
    Jan 2010
    I wanna ask if this works with a nokia 5800 nokia symbian s60v5
    tell me bout fix time please and more personal advices/conclusions
    thanks in advance best regards
    Mar 2006
    Montreal
    fix time is a joke, i use the USB to keep it direct to pc so it always charges at same time, and when carpc is off the gps is in standby, no need to FIX and i get signal inside garages. Ive tried it on blackberry bold and its fast, off and on hits less than 15 secs sync plus it can handle multiple bluetooth connections and usb data at same time without crashing... and i aint complaining about the 100$ price tag as the BU-353 GPS was same price 3 years ago and the signal and sync sucked big time... on top of it, no more cursor jumps from gps sitting at intersections or going downtown, MTK chipset wins..
  1. Question on Garmin 16 GPS receiver
    By cproaudio in forum GPS
    Last Post: 05-23-2008, 02:32 AM
  2. Holux GM-213 USB GPS Receiver, Good?
    By girbot in forum GPS
    Last Post: 04-24-2006, 12:35 AM
  3. New GPS receiver detcts Speedcams
    By ShawJohn in forum GPS
    Last Post: 05-02-2005, 11:00 AM
  4. Proper Installation of GPS Receiver
    By ummagawd in forum GPS
    Last Post: 04-22-2005, 12:07 PM
  5. $69 12 channel GPS receiver - anyone tried this one?
    By LCDcrazy in forum General Hardware Discussion
    Last Post: 09-05-2001, 01:50 PM
Tags for this Thread
